what size turbo?
Old Aug 10, 2001 | 10:17 PM
SiRkid's Avatar
Default what size turbo?
I am getting a t3/to4E turbo for my SiR(b16 engine of course).
I dont know what trim I should get. I am thinkin 54 or 57 but could use a little help.
what do you guys think?
i will be running at low psi for at least a year (or until I get my motor built)...then after that...whatever the motor can take/turbo can dish out
I got a ride in a delsol(with b16) and he had a 50 trim.
but what are your recommendations?
[Modified by SiRkid, 7:18 AM 8/11/2001]
Old Aug 10, 2001 | 10:30 PM
PureTeg420's Avatar
Default Re: what size turbo? (SiRkid)
Not really a huge difference, but if you plan on Dragging the car a lot when the engine's built go with the 57. If it's gonna be your daily driver however, you will want as little lag as possible. I've got a T3/T04e .48 and if it wasn't for the Ball Bearing center, I'd have gone with a T-3 super 60 cause of lag issues
Old Aug 11, 2001 | 01:39 PM
SiRkid's Avatar
Default Re: what size turbo? (PureTeg420)
i see..thanks.
t3 super 60 would die out on the top i think for my engine.
this will be my daily driver.but im not looking for more power to get around town(well i will have a lot more power but a down low{2000rpm} punch is not really what im looking for..i want more power for when im racing(drag or track)..so I think the 57 is a good choice.agree??
how fast will this bad boy spool? full boost at 4000????
and 3500 for bb?
[Modified by SiRkid, 10:40 PM 8/11/2001]
Old Aug 11, 2001 | 02:56 PM
PureTeg420's Avatar
Yeah 57 trim should have full boost at 4000-4250 depending on how free flowing you are from the downpipe back, and about 500rpm less for BB. I didn't realize you had the Si, I was thinkin you were drivin the EX. Yeah 57 trim sounds good for what your lookin for.
Old Aug 11, 2001 | 03:00 PM
SOHCArchangel's Avatar
Who needs boost in 1st gear??? i say t-66
Old Aug 11, 2001 | 03:20 PM
chri5's Avatar
Default Re: what size turbo? (SOHCkordVTEC)
Thta's what I'm saying. I mean hell they used them in F&F so they must be good right
Old Aug 11, 2001 | 05:50 PM
LsTurbo91's Avatar
Default Re: what size turbo? (Strng1dah)
Yup, they only finished the 1/4 mile in 5 minutes or so!!
Old Aug 11, 2001 | 09:34 PM
SiRkid's Avatar
Default Re: what size turbo? (9psiLsT)
ehehhehee
so 57 trim it is!
I want to get the BB option but I am afraid that if something goes wrong...i will have to buy a new turbo...at least i can rebuild (someone that knows how)the regular one...what do you think?
[Modified by SiRkid, 6:35 AM 8/12/2001]
Old Aug 12, 2001 | 06:50 AM
SiRkid's Avatar
after a little more reading..i think 54 would be better!
bb or not??what do you tinkn?
Old Aug 12, 2001 | 03:10 PM
SiRkid's Avatar
is a .63 A/R the right choice for me???????
[Modified by SiRkid, 1:29 AM 8/13/2001]
Old Aug 12, 2001 | 08:26 PM
Armaan's Avatar
With the information given, this would be my recommendation: HKS GT 2835R with a .61 A/R. The 2835R will spool fast, and the tight .61 a/r for the street will give you great response; top end hp will be limited to about 400-450 with the 61. If you don't want the HKS, give Turbonetics a call and ask them for something comparable.
Old Aug 13, 2001 | 08:32 AM
SiRkid's Avatar
Default Re: what size turbo? (2.0L Turbo)
HKS gt turbos will cost out my ***!!!!!!! soo much $$ i have decided what turbo i just want to get the right specs
Old Aug 13, 2001 | 08:05 PM
4dGSR at work's Avatar
BB turbos can be converted at the time of rebuild to sleeve turbo's
just as long as they dont blow up!!!
Old Aug 14, 2001 | 04:29 PM
SiRkid's Avatar
Default Re: what size turbo? (4dGSR at work)
oh.i didnt know that.
hmmmm
Old Aug 15, 2001 | 02:29 AM
IgniteTeg's Avatar
What does the Drag Gen III comes with for a 01 GSR? Which you guyz think i should go with its daily driver and will boost like crazy later on but that be a while. BB or not? What are you guyz setups for the Drag Gen III on a GSR 98+? I'm planin to go with Hondata also which stage you guyz recommend?? Thanks oh btw how safe can i boost with just stock internals with the high CR 10:1??? How many psi of boost can my stock internals handle???? Would I need to PnP my heads? Thanks for all help.
Old Aug 15, 2001 | 03:49 AM
Liltrix's Avatar
Why not give XS-Engineering a call or visit http://www.xs-engineering.com If you are going to call, speak to TRI pronounced "tree". Just tell them what U have and what u will like to have and they will custom make a turbo at a great price.
Old Aug 15, 2001 | 03:53 AM
Liltrix's Avatar
Default Re: what size turbo? (IgniteTeg)
Stock internals can handle up to 8-10 psi, I will not recommend more than that for safety and reliability reasons. U do not need to pnp your head, Hondata stage 2 W/ boost option is sufficient but stage 4 w/ boost has everything, especially if U R going to be tuning your own ride, U can also burn custom chips very cheaply.
Old Aug 15, 2001 | 04:21 AM
R-Rated's Avatar
Will a Greddy T-78 Turbo fit on to a type r motor? If not how come? If it does what will I feel if I do.
Old Aug 15, 2001 | 05:33 AM
redline's Avatar
Default Re: what size turbo? (R-Rated)
A t-78 should be spooled by the time you hit 5th gear. Not the right turbo for a honda.
Old Aug 15, 2001 | 02:45 PM
SiRkid's Avatar
Default Re: what size turbo? (redline)
i have picked my turbo.just dont know what fuel computer **** to use.
hondata ,haltech etc.
96romaEK
May 11, 2010 08:01 PM
Schister66
Feb 21, 2006 12:56 PM
boostdummy
Jan 21, 2006 09:18 PM
riceburnah
Jul 14, 2004 08:02 PM
wappid
Jun 17, 2004 08:22 PM
