rc 550cc injectors or blitz 550 cc injectors??
i'm going to upgrade my injectors from 310cc to 550cc and was just wondering which of these are better. i have the rc 310cc right now but only used them for about 2 months so i don't know how reliable they are in the long run.
if any needs a set of rc 310cc for a 94 ls integra, hit me up.
Re: rc 550cc injectors or blitz 550 cc injectors?? (boostedeg6)
RC no longer makes saturated (high impedance) injectors larger than 440cc.
Only other option would be Venom.
HTH.
How much for the 310s?
HTH.
Re: rc 550cc injectors or blitz 550 cc injectors?? (G3-TEG)
no kidding? so, do you know anything about the blitz injectors?
as for the rc 310cc, i'll let them go for $300 flat because i only used them for about 2 months, if even for that long.
uhh, Import parts was selling 310's brand new for $275. I think $300 for some used ones is a bit steep.
Re: rc 550cc injectors or blitz 550 cc injectors?? (Ray)
Ricoh Racing uses 430cc Supra injectors on their Honda turbo cars. The FC3S RX-7 550cc injectors will fit but the RX-7 inj plugs are also needed.
Re: rc 550cc injectors or blitz 550 cc injectors?? (apexii)
DSM injectors are peak hold and i think that there are some people using them with resistor packs.
k
k
well, my obd1 prelude has the resistor packs so I should be ok.
The 450's should work fine, luckily hondata has that handy-dandy injector multiplier which allows quick injector swaps. I would prefer the 550's but at a third of the cost the dsm's are not looking too bad.
1 Post
yeah I use to use two Mitsubishi Lancer Evolution 3 injectors as my additional fuel injectors, but required the use of some resistors to get them working properly.. they are very well effective.. 510cc each (the ones with the yellow plugs at the top) too.. you'd probably have to create some sort of adapter to get them to fit as main injectors, not quite sure how you'd do it.. but i'm sure there's a way somehow
Re: rc 550cc injectors or blitz 550 cc injectors?? (nathan's boosted civic)
I think 450cc is good for around 16psi but doesnt hurt to have more, then again 550cc usually cost alot more too
