manual boost controller worth it?
Old Aug 15, 2001 | 10:14 PM
Mikex25's Avatar
New User
Default manual boost controller worth it?
I wanted to know if a manual boost controller was worth it, What's the difference between a manual boost controller and when you change boost psi from the top of your wastegate example: deltagate. If there is not difference why get a manual boost controller then?
Old Aug 16, 2001 | 12:48 PM
SW20 MR2's Avatar
Default Re: manual boost controller worth it? (Mikex25)
With a MBC, you just buy one spring - the minimum boost that you'll be running - and changes can be made simply by turning a ****. If you change it via the wastegate, you have to swap out the springs each time. It's just a little easier with the MBC.
Old Aug 16, 2001 | 03:37 PM
SIK IN DA HED's Avatar
New User
Default Re: manual boost controller worth it? (SW20 MR2)
hahah this was the same question i posted a few weeks ago. i dont think its worth it. get an electronic boost controller. its alot better.
Old Aug 16, 2001 | 03:44 PM
Ri5e's Avatar
defienetly. it will make the turbo spool up faster. because with the wastegate alone, the wastegate opens gradually as the boost increases. With the MBC, it'll keep the wastegate shut (which helps the turbo spool up faster) until full boost.
5thGenCivicKid
Mar 26, 2005 11:40 PM
zseeanz
Nov 11, 2003 07:50 PM
_Shadow_
Oct 19, 2002 05:38 PM
Tofurky
Aug 6, 2002 10:11 PM
teamrocket si
Feb 10, 2002 02:27 PM
