chipped ecu for b20 turbo?
i remember reading somewhere here long time ago(couldnt find it in seach) about someone having a b20 turbo running over 8psi on a chipped ecu(think it was a zydne ecu). now currently on monday i will be starting on my b20 turbo project.
the setup includes
t3 turbo w/ internal wg (yes i kno small turbo only for the time being)
walboro 255 fuel pump
fpr set @42psi
12:1 fmu disc
440cc injectors
8psi
ls ecu
now would it be safer to run a afc hack instead of a fmu or fmu w/ a chipped ecu for the basemap of my setup??????
i just want the car to run reliably and safely until i get the hondata which wont be for another 3 months.
thanks for any help
cliff
the setup includes
fpr set @42psi
12:1 fmu disc
440cc injectors
8psi
ls ecu
thanks for any help
cliff
Re: chipped ecu for b20 turbo? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">just run uberdata and forget about that hack/fmu crap.</TD></TR></TABLE>
lookin into uberdata now but does anyone have a map for a turbo b20z i have searched and even talked to newman he said xs engineering made his chip so i am lookin into that now but still havent found anything on it
Re: chipped ecu for b20 turbo? (bruceHungLO)
The map I did for JalopSiR that made 206 whp @ 6 psi, I started with an LS basemap and took out 10% fuel over 4500 rpm. From there you can recurve for larger injectors, add your ignition retard, etc, with UD or the like. The B20B/Z is, like it or not, an LS engine.
Re: chipped ecu for b20 turbo? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">The map I did for JalopSiR that made 206 whp @ 6 psi, I started with an LS basemap and took out 10% fuel over 4500 rpm. From there you can recurve for larger injectors, add your ignition retard, etc, with UD or the like. The B20B/Z is, like it or not, an LS engine.</TD></TR></TABLE>
would u be able to make a chip for me? interested PM meeh
I'm not interested in tuning your car by mailing chips to you.
If you want to buy a wideband and a chip burner, I'm more than happy to help guide you through and do a little hand holding for free... but I'll make you read a lot of how-to **** on the Uberdata Forum before I let you bother me. Basically, you'll have to meet me halfway, and do half the work required to learn - at that point the tips and tricks I kick you won't sound like gibberish, as you'll be ready to learn them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">I'm not interested in tuning your car by mailing chips to you.
If you want to buy a wideband and a chip burner, I'm more than happy to help guide you through and do a little hand holding for free... but I'll make you read a lot of how-to **** on the Uberdata Forum before I let you bother me. Basically, you'll have to meet me halfway, and do half the work required to learn - at that point the tips and tricks I kick you won't sound like gibberish, as you'll be ready to learn them.</TD></TR></TABLE>
thats understandable jesus lol. this whole learning thing i am already reading on that for the past 2 days
