What does a guy need to do to install DSM 450cc injectors on a OBD1 Honda???
The topic explains it all. I have a D16Z6 engine in my Sol and I want to upgrade in injector size for my turbo. What do I need and what do I need to do?
Re: What does a guy need to do to install DSM 450cc injectors on a OBD1 Honda??? (4NBliss)
if you want dsm injectors you will def need a vafc/safc or you ll be running wayyyyyyyyyyy too rich and idle will suck like you never know.
heres a link on the how tohttp://www.homemadeturbo.com/tech_projects/dsm_injectors/index.html
your going to need:
the 450 injectors
a resistor box or 10 watt 10 ohm resistors
and somthing to control the injectors such as (smc, v/s afc, or a chipped ecu running uberdata etc.) if you want to do it the right way just chip your ecu and run uberdata.
For more info on uberdata and chipping your ecu just search there's tons and tons of info out there.
the 450 injectors
Yep what he said.
Oh and if anyone needs resistor boxes I have some for sale (in my sig)
There are also instructions on how to install resistor boxes WITHOUT cutting your OEM wires.
hondaluver12
06-25-2009 03:39 PM
NeXtLeVeL_TyPe_R
02-23-2003 08:22 AM
