Dp Fix (pictures)
Old Jun 27, 2004 | 11:01 PM
done's Avatar
Default Dp Fix (pictures)
Is it possible to pick up power when bolting an exhaust up? rather then running open header/dp?
full race sent me a b16 dp the 1st time, they sent me a new b18c5 one. i had it extended to fit my exhaust. all i had to do was get the flange welded on . No problem with the help of my friends neighbor
Got the car on the stands.
Alot of random parts siting around
photos during process
check out the cover
Finally product
the man himself.. I cannont thank him enough
cademan giving it a shot
me messing around
the car feels alot more responsive and seems to rev alot faster. The turbo comes on about 100rpms later, Its about 3lbs 4300rpms-4800rpms its 7lbs.
it spins alot more. i need tires i think.
Hope you guys like the pictures
Old Jun 27, 2004 | 11:13 PM
Rob Dizzle's Avatar
Default Re: Dp Fix (Jordo)
always cool pics jordo
i dunno about the exhaust thing. i dont have any direct experience with no exhaust vs full exhaust dynos.
Old Jun 28, 2004 | 12:53 AM
c jackson's Avatar
threes
Default Re: Dp Fix (Bob-DC2)
yes it is possible. its all in the timing.
Old Jun 28, 2004 | 01:57 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Dp Fix (c jackson)
dam those are nice..
Old Jun 28, 2004 | 03:08 AM
JDMCRX's Avatar
Default Re: Dp Fix (bruceleeroy)
Nice work guys i wish i had a tig welder
Old Jun 28, 2004 | 05:08 AM
SiRkid's Avatar
duuuuuuuuuuuuuuude, what the hell do you do for work?
awesome btw
Old Jun 28, 2004 | 05:20 AM
B16A1-EF9's Avatar
Remember that when you remove the exhaust it should lean up the mixture alittle. When you but the exhaust back on it richens a bit. That cold be why...
Old Jun 28, 2004 | 05:53 AM
FOrSfEd's Avatar
Default Re: Dp Fix (B16A1-EF9)
Hella nice pics bro
Old Jun 28, 2004 | 06:12 AM
GEN2TEG's Avatar
Looks really good! Nice teg!
Old Jun 28, 2004 | 06:21 AM
Ri5e's Avatar
Default Re: (GEN2TEG)
Nice SS downpipe
Old Jun 28, 2004 | 06:42 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A1-EF9 &raquo;</TD></TR><TR><TD CLASS="quote">Remember that when you remove the exhaust it should lean up the mixture alittle. When you but the exhaust back on it richens a bit. That cold be why...</TD></TR></TABLE>
The reason it leans out when you pull off the exhaust is because the car is making more power and therefore would need to burn more fuel to maintain the same AFR. When the same amount of fuel is present, the mixture leans out.
Old Jun 28, 2004 | 08:23 AM
done's Avatar
the car was tuned with open dp, might be time to jump on the dyno now.
Old Jun 28, 2004 | 08:26 AM
Muckman's Avatar
Moderator in Chief
Awesome car. Are those SSR Comps? What size wheels?
Old Jun 28, 2004 | 08:29 AM
done's Avatar
Default Re: Dp Fix (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Awesome car. Are those SSR Comps? What size wheels?</TD></TR></TABLE>
they are custom painted Advan RGs, 16x7.5
Old Jun 28, 2004 | 08:42 AM
alpha's Avatar
Sweet Jordo
Old Jun 28, 2004 | 09:15 AM
fastcivicboy's Avatar
off topic but nice pics. What kinda of camera are you using?
Old Jun 28, 2004 | 09:39 AM
Rocks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
they are custom painted Advan RGs, 16x7.5</TD></TR></TABLE>
Damn they look good.
Old Jun 28, 2004 | 09:50 AM
done's Avatar
Default Re: (fastcivicboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcivicboy &raquo;</TD></TR><TR><TD CLASS="quote">off topic but nice pics. What kinda of camera are you using?</TD></TR></TABLE>
those were taken with cademans olympus c750
Old Jun 28, 2004 | 09:57 AM
Full-Race Geoff's Avatar
looks nice jordan, glad to see the new dp worked out!
more than likely your tuner coul dhave made thigns a bit richer, cars always lean out on the street vs dyno
Old Jun 28, 2004 | 10:47 AM
Chip's Avatar
Default Re: Dp Fix (Full-Race Geoff)
Jordo, how do you like the thermal catback? How loud is it compared to an N1 on a turbo car, if you've heard an N1? How does it compare to the stock ITR catback when naturally aspirated?
Old Jun 28, 2004 | 03:01 PM
done's Avatar
Default Re: Dp Fix (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">Jordo, how do you like the thermal catback? How loud is it compared to an N1 on a turbo car, if you've heard an N1? How does it compare to the stock ITR catback when naturally aspirated?</TD></TR></TABLE>
i swear its quiter then stock... until i hit boost and wastegate opens
but going from stock/test pipe to open dp for a month, then to thermal 3"
Turbocivic94
Welding / Fabrication
140
Aug 3, 2006 03:57 PM
done
Jun 28, 2004 07:09 PM
fastwanabe
36
Mar 7, 2004 06:14 PM
lukedogg49525
Jun 29, 2002 12:39 PM
