Missing Link + Emanage, can it be done
Old Jun 28, 2004 | 05:22 PM
94greddycivic's Avatar
Default Missing Link + Emanage, can it be done
i know that the emanage runs off the map sensor so i didnt know if this was ok to use them together and if it would allow the car to run right...does anyone on here run a missing link with the emanage...if so how does it work...did you get rid of CEl 3
Old Jun 28, 2004 | 06:25 PM
Default Re: Missing Link + Emanage, can it be done (94greddycivic)
bump
Old Jun 29, 2004 | 03:41 AM
hearing mixed things can i get a yes or no on this
Old Jun 29, 2004 | 04:06 AM
notoriousB's Avatar
not too familiar w/ e-manage but if your map sensor is blinded from boost (missing link) the ECU won't be able to compensate fuel for boost if it goes off the stock map sensor reading, so IMO, no, don't do it.
Old Jun 29, 2004 | 06:38 AM
excessive's Avatar
You have to set up the clamp voltage in the boost cut. Usually somewhere around 2.6 volts then you do the boost portion of the inrichment on the additionalfuel map.
Do not use the missing link.
Old Jun 29, 2004 | 10:51 AM
^can i do this using the emanage software with out erasing the base map
chrisfromsrq
Sep 26, 2009 12:20 AM
nicktagz
Sep 8, 2006 11:01 AM
l2yanE
Oct 2, 2005 10:15 AM
TurboLude97
Apr 30, 2003 05:12 AM
schwett
May 15, 2002 01:01 PM
