Finally got it to idle decent...but, more issues...
Old Jun 25, 2004 | 11:30 PM
*Boostwerks*'s Avatar
Default Finally got it to idle decent...but, more issues...
Well, I finally got my GSR motor to idle decently, but I'm still having issues.
Whenever I give it throtal, it doesn't want to rev up. It kinda feels like and sounds like, its hitting a rev limiter.
The timing is fine, and I have only 1 code (IAC...to which I don't have ).
The only problem I'm having other than this, is I havn't been able to adjust the GM TPS above -3%, but I've been told that it should rev despite this. I should be able to oriente the senser so Its at zero, but I havn't done so yet.
What could be causing the motor from reving?
Thanks for any help!
Old Jun 26, 2004 | 01:30 AM
Kwuaymaikrup's Avatar
Default Re: Finally got it to idle decent...but, more issues... (Bryson)
Is your MAP sensor wired correctly? When mine was wired wrong I couldn't get it to go past a couple hundred RPM's before it seemed to hit a rev limiter like you described. Hope this helps.
-Ryan
Old Jun 26, 2004 | 10:07 AM
Default Re: Finally got it to idle decent...but, more issues... (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">Is your MAP sensor wired correctly? When mine was wired wrong I couldn't get it to go past a couple hundred RPM's before it seemed to hit a rev limiter like you described. Hope this helps.
-Ryan</TD></TR></TABLE>
I havn't touched the wiring of the map, but I will check it just to make sure.
millsd4
Aug 17, 2008 03:59 PM
lsturbo*
May 21, 2008 01:48 PM
fadedgsr
Apr 5, 2008 03:30 AM
baonest1
Aug 17, 2003 05:51 PM
t5er
Dec 15, 2002 07:25 AM
