is porting my ls head worth it?
Old Jun 25, 2004 | 06:25 AM
spoon23_JDizM AkA SpOoN20's Avatar
Default is porting my ls head worth it?
or will dual valvesprings-retianers and valves with turbo spec cams be fine????with no porting done?this is to a 98 ls head aswell...
Old Jun 25, 2004 | 06:59 AM
Default Re: is porting my ls head worth it? (spoon20)
answer the damn ???? fellaz...jp....
Old Jun 25, 2004 | 08:30 AM
Blaze45's Avatar
Brrraaaap!
If you get a set of cams, you will really notice a difference if the head is p&p. It will flow better and make more power @ any RPM. Its kinda like using Hondata and injectors. You just do both at the same time. Catch my drift?
Good Luck
Blaze
Old Jun 25, 2004 | 04:37 PM
Default Re: is porting my ls head worth it? (Blaze45)
werd...
Old Jun 25, 2004 | 05:13 PM
Fastrex702's Avatar
http://cgi.ebay.com/ebaymotors...33617. Looks like a good deal.
Old Jun 28, 2004 | 12:38 PM
Default Re: is porting my ls head worth it? (Fastrex702)
anyone else ???
Old Jun 28, 2004 | 01:07 PM
Joseph Davis's Avatar
Worth it for what? What are your power goals?
Old Jun 28, 2004 | 01:31 PM
Muckman's Avatar
Moderator in Chief
I doubt it would be worth it. Can anyone show me numbers proving that a P&P LS head can flow any better than a stock GSR head? Its so damn expensive too!
Old Jun 28, 2004 | 01:59 PM
patdemps's Avatar
Default Re: is porting my ls head worth it? (Muckman)
If you want to open up that head then go ls/vtec and get yourself a GSR head.
Less downtime, less money. Just my way of seeing it.
Old Jun 28, 2004 | 05:29 PM
Default Re: is porting my ls head worth it? (patdemps)
just boost it...
Old Jun 28, 2004 | 07:53 PM
last words be4 i make my mind up...
Old Jun 29, 2004 | 01:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon20 &raquo;</TD></TR><TR><TD CLASS="quote">last words be4 i make my mind up...</TD></TR></TABLE>
You never answered my question, so you'll not get my advice. Go ahead and decide, but I can't see what the point of asking in the first place was if you don't have any goals for the vehicle.
Old Jun 29, 2004 | 04:53 AM
BoostedsiR's Avatar
Default Re: is porting my ls head worth it? (J. Davis)
I know it is a hassel but you will be better off if you just get a vtec head and you wont need to worry about any of this, unless you are trying to make some crazy power.
Old Jun 29, 2004 | 06:23 AM
Default Re: is porting my ls head worth it? (BoostedsiR)
put it this way i'll be happy with 350hp
Old Jun 29, 2004 | 04:32 PM
Old Jun 29, 2004 | 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon20 &raquo;</TD></TR><TR><TD CLASS="quote">put it this way i'll be happy with 350hp</TD></TR></TABLE>
Stock head, cams, and valvetrain - maybe a hair stiffer spring on the exhausts to help get heat out of them, but not manditory. Save the money for oil changes and a set of tires every 2000 miles. Please drive through.
Old Jun 29, 2004 | 09:50 PM
Rod.'s Avatar
I was thinking the same thing spoon20. I just made it kind of easier for myself and picked up a b16 head
Old Jun 29, 2004 | 09:53 PM
shermanyang's Avatar
i'm porting a spare ls head that i got from a buddy and slapping it on to my current setup. i'll post up both dyno graphs and you can compare for yourself if it's worth it or not.
i didn't want to go LS/Vtec because of the hassle of having to retune for vtec and redoing all the oil lines...yade yade yade, and the compression bump not to mention since i'm running stock comp. JE's.
just my .02, the LS head flows like **** so any type of modification that helps it breath better is worth it IMO. if you know what you're doing, just use a dremel and open up the intake and exhaust ports on your LS head.
Old Jun 30, 2004 | 01:30 AM
Default Re: is porting my ls head worth it? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">just my .02, the LS head flows like **** so any type of modification that helps it breath better is worth it IMO. </TD></TR></TABLE>
Like, turning up the boost? Or putting a Roots into the system to promote scavenging like the old SI aircraft or, uhm, twin charged Detroit Diesels?
There are several different interpretations of breathing better if you ignore junk flowbench numbers that don't mean anything anyway, just like boost figures don't mean anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote"> if you know what you're doing, just use a dremel and open up the intake and exhaust ports on your LS head.</TD></TR></TABLE>
If you know what you are doing, bowl and ssr work is what you focus on. A smaller port + higher charge velocity + faux perception of "high boost is bad" doesn't have a great bearing on the subject. This is not NA, you just need to be worried about balanced flow to create good power.
Snailor Built
Sep 15, 2009 08:34 AM
85
Feb 1, 2006 09:50 PM
89a6T
Dec 1, 2005 08:52 PM
b20turboic
Nov 20, 2005 07:59 AM
scatuli
Nov 21, 2003 08:01 PM
