EF B series swap..... that turbo will clear full-size radiator ?
I'm going to be boosting my recenly swap b18c1 in my ef.
I need a new radiator. I know that my apexi turbo kit and downpipe will have pently of room but I wanted to see what other guys were running with a FULL radiator?
list turbo & manifold and downpipe.
Re: EF B series swap..... that turbo will clear full-size radiator ? (Charlie Moua)
if you go with a t3/t4 your gonna have trouble with a full size radiator working i have a inline pro and garret turbo compressor on driver's side with an eg radiator
good question...
I will find the answer friday when I start my install.
B16
revhard mani
T3/T4
B16
revhard mani
T3/T4
i am not a B series but i shall give u an idea
i got a D16Z6 SOHC VTEC
with a HF manifold, 14B turbo, homemade dowpipe and such.....and my actual turbo compressor housing is about 1/2-3/4 " away from the actual radiator.. perfect fit if u ask me
Re: (ricodemus)
i used a eg civic radiator and still had problems. its pretty ****** tight in there. i turned the turbo where the exhaust side is on the left and made a straight shot downpipe with no left or right bends. i recconstructed my crossmember to help with mounting the radiator. one of the best things to do is get an aftermarket one of fab. i trippin on how the one in that pic got that in. madd props. good luck bro i had a hard time.
Re: (B20vtec81)
I have a pic on my pc at home of a crx with hasport mounts, an inline pro manifold and a full length fluidyne. And yes, I plan on having the compressor on the driver's side.
Re: (ricodemus)
My setup was, HCP, stock radiator, DRAG3 mani, custom DP, T3/T4E facing the passenger side. No problems. I have since changed to an EG/EK Fluidyne radiator and Jim Fab Craoss-member. Much nicer to work with.
Re: (Doodoo)
Re: (keithv)
Hey keithv!! yes yes thats my old setup, RIP baby. She will be back later this year with a new motor, same turbo. I thought those pics were gone off the net forever.
Re: (Brad)
Brad, do you have a pic of you drivers side IC piping? I can't figure out how to get the IC piping right on the drivers side.
I see that you used your air intake pipe as IC piping. Doesn't it lower your boost a lot because of the larger diameter? Do you notice it while driving?
Re: (JOeS)
the ic pipe snakes towards the passenger side between the crossmember and tranny to dsm sidemounted ic. I don't drive the car, but I've messed around with different size ic pipes and didn't really feel a difference.
10psiLsEf2
11-20-2011 06:04 PM
Dancing is Forbidden
10-27-2005 06:33 AM
sneakypete
01-13-2003 10:31 AM
