Help with d16 fuel management w/T25...
I'm installing a T25 w/stock internal w.g. on my d16y7. For the time being I will be running non-intercooled, with a P06 ecu, a Y8 manifold & t/b conversion.
My concern is with ignition and fuel control. Can I run this setup at 8psi or less with no ignition retard if I use 93 octane?
My big question also is does a Greddy blue box use bigger-than-stock injectors? I have a set of RC 440's, or I can use the Y8 stock ones. I was going to get Hondata to use with the 440's but I might not be able to afford it so would a blue box do good with my mild setup and what injectors do I use. Are all the blue boxes the same or are they different between Tegs/Civics?
Thanks, help me out so I can get what I need to finish the project!!!
Re: Help with d16 fuel management w/T25... (klungemonger)
I wouldnt run anything with an intercooler, even if you find a small cheap one its 10 times better than none..
If you want to run with no ignition timing retard then I would retard it at the dizzy.. Boost itself doesnt make power without everything set correctly around it..
Re: (T-RO)
I checked out Uberdata as you suggested, it seems like it could be tricky to get prefect...BUT, I decided to try it anyways! So I ordered a ROM burner and the ecu hardware, saved $300+ over hondata...
There's a guy with a setup similar to what I will have who is working to get his dialed in, so when I'm ready I'll be borrowing his bin file to get mine going! Thanks for the tip...
PS - now I'll probably be able to afford the fmic too!!!
http://www.johnnyracecar.com has the cheapest intercoolers around. I bought a 5" from them and am very happy
boostincoupe
05-28-2003 09:02 AM
