Turbo not spinning while idle ?!
Old Jun 26, 2004 | 02:15 PM
DrunkenMaster16's Avatar
Default Turbo not spinning while idle ?!
First off, I am not getting ANY boost at full throttle or partial throttle. The gauge goes to 0 mmHg, , then nothing above that.
I have the intake tube off of the turbo and while the car is idling, the blades of the cold side are not spinning. When I rev the engine, the blades will start spinning, but once I let off... the blades will stop spinning rather quickly.
Is this normal ? I've been looking for any leaks in the piping, but nothing and can't figure out why I'm getting no boost. Could my center section need a rebuild ?
Old Jun 26, 2004 | 03:09 PM
AB16A2T's Avatar
Default Re: Turbo not spinning while idle ?! (DrunkenMaster16)
They should spin at idle. Probably won't create boost when just revving it but they should spin.
Old Jun 26, 2004 | 03:19 PM
specv5150's Avatar
Default Re: Turbo not spinning while idle ?! (AB16A2T)
Yeah something is def wrong with your turbo. I had a massive exhaust leak at the manifold and my blades were still spinnign at idle.
Old Jun 26, 2004 | 03:46 PM
Frozen E's Avatar
H-T White Ops
Are you getting good oil flow to the turbo bearings? Maybe they're cooked? If that's the case it's probably too late by now anyway. Sounds like you're getting some friction in there. Not good.
Old Jun 26, 2004 | 03:56 PM
Jared's Avatar
it depends on the turbo and engine, a smaller engine will not spin a larger turbo at idle.
Old Jun 26, 2004 | 03:59 PM
specv5150's Avatar
Default Re: Turbo not spinning while idle ?! (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">it depends on the turbo and engine, a smaller engine will not spin a larger turbo at idle.</TD></TR></TABLE>
So.....if you had a 1.6 SOHC and a big *** turbo, the blades wouldnt spin even at idle...just from the exhaust going from the manifold to the muffler?? Not trying to call you out, just trying to get a better understanding of what you are saying
Old Jun 26, 2004 | 08:01 PM
My buddy says he's never seen a turbo not spin at idle, ,he thought it would be the bearings too.
Any other ideas/opinions ?
Old Jun 26, 2004 | 08:12 PM
project dc2's Avatar
Default Re: (DrunkenMaster16)
how about yout ell us your set up ?
Old Jun 26, 2004 | 08:51 PM
shadow103rd's Avatar
I agree. A 1.6 SOHC probably wouldnt spin an SC61 at idle . But I mean it would have to be a big *** turbo....just my $.02 cents
Jon
Old Jun 26, 2004 | 09:01 PM
Bailhatch's Avatar
Default Re: Turbo not spinning while idle ?! (shadow103rd)
I have seen plenty of turbos not spin at idle. as long as it spins when reved your probably fine. 90% sure your problem lies elsewhere. I would guess a blow off valve problem or the wastegate is stuck open or something.
Old Jun 26, 2004 | 10:48 PM
SBCCIVIC's Avatar
Default Re: Turbo not spinning while idle ?! (Bailhatch)
what does your car idle at? that may have something to do with it, the tubine wheel is not completely sealed inside the housing it may only have enough air to creep around the blade and slip out the turbine. it is totally normal for it not to spin at idle. but for some motors and different setups it may not be, might wanna check the play in the shaft too.
compton
Old Jun 26, 2004 | 11:07 PM
Default Re: Turbo not spinning while idle ?! (H22 TURBO'D HATCH)
My car Idles at 1500 - 3000 rpm and sounds like a scoobie, once I put it in gear it lowers but is still loud as hell. My setup I have a D15Z4 ( JDM ) its 1.5. I have a 2ft long by 1ft high intercooler mounted infront. I normally start to spool at 2500 RPM and hit boost at 3000 full boost at 3500 - 4000. My turbos a RX7 2nd gen ( HT-185-25), I have 2 1/2 inch exaust pipe a cat and 2 resinaters. It is automatic ( My mother used to drive it) Im about ready to install a gearbox. Oh and my internals are stock otherwise.
Thanks for all your input im going to take the turbo off and see if i can get a turbo specialist to look at it and see if he can fix it. Other wise im thinking about getting a B16A2 - B18 and boosting it ( im adicted to boost.)
Old Jun 27, 2004 | 12:16 AM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkenMaster16 &raquo;</TD></TR><TR><TD CLASS="quote">My car Idles at 1500 - 3000 rpm and sounds like a scoobie</TD></TR></TABLE>
Sounds like you may have other issues beyond the turbo. A 1.5 SOHC may not provide enough gas exhaust volume to spin the Hitachi at "idle".
Old Jun 27, 2004 | 02:11 AM
Frozen E's Avatar
H-T White Ops
Even if the thing doesn't spin at idle (which I don't see why it wouldn't if it idles at 1500 RPM) why would it come to a quick stop when he lets off the throttle? Any turbo with good bearings is going to sit there and freewheel for a while even if there's no exhaust going through it. I think it's your bearings.
Did you buy the turbo used? I'm guessing it probably wasn't taken care of very well. How is the shaft play on the turbo?
Old Jun 27, 2004 | 05:01 AM
svmnredracr's Avatar
Just having an similiar problem, but if the seals are good, now what can yall say? I have bought an new turbo and still dont spin..we all know what it takes to make it spin but its not even though the engine is fine..just damn weird..phuc
Old Jun 27, 2004 | 08:03 AM
Pfieff's Avatar
I have a t3/to4e 50 trim on a d16y7 and it doesn't spin at idle(800rpm) but once it revs to a little over 1.3k rpms it will start to spin.
Old Jun 27, 2004 | 08:16 AM
98gsrTEG's Avatar
Default Re: (Pfieffdog)
if you just installed the turbo and it is brand new, it won't spin at idle untill it is fully heat cycled. i thougt the same thing untill i drove around for an hour, came back home and saw it was spinning at idle
99civicsiboosted
77
Jul 8, 2010 10:09 PM
vtec_killer_
Mar 18, 2008 08:53 PM
tranceologist
Sep 17, 2005 12:58 AM
project civic
Mar 31, 2005 09:38 AM
311
Jun 22, 2002 03:13 PM
