83mm sleeved closed deck block can it be daily driven?
83mm sleeved closed deck block can it be daily driven?? will there be any problems with over heating because of the closed deck? any info with closed deck block will help me out..
Re: 83mm sleeved closed deck block can it be daily driven? (jkjb16a)
yes it can. I havent realy heard of that many overheating problems with closed deck blocks. If you are worried why not just get an open deck design?
Re: 83mm sleeved closed deck block can it be daily driven? (AVATAR)
i have the block it was a x-mas present and I'm just getting the money to put it together..
Just make sure your cooling system is in tact and you should be fine. Rad, hoses, rad cap, thermostat etc.. are all very important when it comes to keeping the motor running cooler. Make sure that they are in top shape and you will be fine.
You could also ask around those who sport the DART race blocks as they are also a closed deck design.
Goodluck.
Goodluck.
Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">for added cooling get a aluminum radiator, they work great for keep your motor cool, and you will be fine with the closed deck </TD></TR></TABLE>i have a aluminum radiator pwr thanks
