what is the ideal management system for a DOHC ZC with 8psi?
Old 06-28-2004, 04:45 PM
littledevil's Avatar
Default what is the ideal management system for a DOHC ZC with 8psi?
Hey, I just finished building my homemade turbo kit, I have everything together and ready to bolt on. but I am unsure as to what I should do for fuel management.
I am running a budget set-up and was hoping there is a good reliable but affordable way to finish this. Please help? thanks
Old 06-28-2004, 05:04 PM
Default Re: what is the ideal management system for a DOHC ZC with 8psi? (littledevil)
forgot, I have an 88 crx si, with a zc dohc engine. obx intakemanifold, integra throtle body, cold air intake, 2.25inch exhaust, msd blaster coil/cap. thats basicly it
Need to know what ecu/fuel mangement to run asap! thanx
Old 06-28-2004, 05:08 PM
ek_99_SiR's Avatar
safc2
Old 06-28-2004, 05:13 PM
86si's Avatar
zdyne gold ecu,thats what I use with my zc boosted to 23psi
Old 06-28-2004, 05:17 PM
Default Re: what is the ideal management system for a DOHC ZC with 8psi? (86si)
zdyne gold ecu, safc2, what do they cost and what are the advantages/disadvantages. also I have two intercoolers, which is better, audi 3000 front mount and eclispe side mount. thanx again for the help!
Old 06-28-2004, 05:24 PM
xenocron's Avatar
If you are OBD0... Turboedit <---FREE $$$
If you are OBD1... Uberdata <---FREE $$$
86si's Avatar
8psi isn't much boost,both intercoolers would be fine.Safc only manipulates the fuel system and is very limited.The zdyne is a plug and play with a launch,revcontol etc. It cost is about 950.oo U.S. and the afc is 500.00.Go with the zdyne you won't ever need anything else!
Old 06-28-2004, 05:30 PM
Default Re: what is the ideal management system for a DOHC ZC with 8psi? (xenocron)
xenocron, it won't let me Pm cause I am a new member, tell me more about turboedit? I have an 88 crx si ecu, an 1990 teg ecu, think they are obdo1?
please give me the info. thanx
Old 06-28-2004, 05:33 PM
Jim Truett's Avatar
Here are two links:
http://www.homemadeturbo.com/f...ard=6
http://www.turboedit.org/
Old 06-28-2004, 06:40 PM
MooreBoost's Avatar
Default Re: what is the ideal management system for a DOHC ZC with 8psi? (Jim Truett)
I run the hack with a BTM, only because my ECU could not be chipped for TE.
Old 07-01-2004, 02:37 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littledevil &raquo;</TD></TR><TR><TD CLASS="quote">xenocron, it won't let me Pm cause I am a new member, tell me more about turboedit? I have an 88 crx si ecu, an 1990 teg ecu, think they are obdo1?
TurboEdit is a FREE editor that Jason Parker created in his spare time. This editor manipulates the fuel and timing maps of an OBD0 (PM6 ECU specific) code base.
Basically, you chip a 90-91 PM6 ecu, manipulate the free ECU code with the free editor and then burn a chip and put it in your car.
It's definitely not a plug n play option (and neither is ZDYNE for the people who said this). You need to understand tuning or be able to take it to someone who can help you tune in your car.
Your 88 ECU probably wont work. The PR4 from the 90 teg probably will...to some extent. Best bet is to find a PM6 ECU.
Email me...I have a few PM6 ECUs that I am selling and will whip up a basemap for your engine and the configuration that you are going for. Then from there you find someone local to help you tune or learn yourself and go from there.
cwharris@optonline.net
Also, I made some writeup that might help get you started understanding TurboEdit.
http://www.xenocron.com/te/
Also check out:
http://www.pgmfi.org
http://www.homemadeturbo.org
http://www.d-series.org
There is a lot of info about TurboEdit and many users on these sites.
Good luck.
knightsef-eg
10
07-30-2009 11:11 AM
trepteg
08-21-2007 02:55 PM
BlueRex1020
10-11-2006 05:03 PM
EFHATCH11
03-17-2006 04:46 AM
ZColeon
01-14-2002 06:51 PM
Quick Reply: what is the ideal management system for a DOHC ZC with 8psi?
