FAST 4 door Tegs .. Any out there in the 11-12's?
I'm gonna be goin to the track next saturday w/ my new setup in my 4dr teg LS.. I'm hoping to run low 12's and even dip into the 11's..
Its my daily driver w/ full interior
My Setup:
fully built Benson sleeved to 84 mm
weisco pistons / eagle rods
hondata w/ 3 bar map sensor
sc61, pte 600 hp FMIC,
38 mm tail WG w/ 14psi spring
full 3" exhaust, quaife LSD, REV valve springs/retainers
9.5K redline
24.5x8x15 slicks
and hoping to run 20 psi on 100 octane
To those who've been there, what do ya predict my setup will net me..??
My Setup:
9.5K redline
24.5x8x15 slicks
Re: FAST 4 door Tegs .. Any out there in the 11-12's? (92HB_HB)
All depends on what you dyno at and what your car weighs, but I think you should hit at least high elevens or low twelves with that set up.
I think if you get a good launch you should beable to do low 12's maybe high 11's , your horsepower is what will make the diffrence, but i can garentee you 12's just hard to say more without knowing your hp numbers. on a stock motor last year running 8-9 psi with a closed loop wastgate i ran a 13.1 with a 2.41 60'' which if my 60'' was better i would have hit 12's but no traction, and this is in a full interior db8 btw mine is a gsr
s2kboy03
Honda S2000
12-11-2004 10:12 PM
92HB_HB
07-11-2004 07:11 PM
92HB_HB
07-01-2004 10:11 PM
