ZEX dry kit on d16z6 (some fuel questions)
Ok right now i have intake and exhaust, and some ngk irdium plugs. im running a 65 shot right now, thinking about doing a 75 shot. what are some ways that i can run better fuel because i've been doing some research that i should buy a a new fuel pump. What do you guys reccomend me doing exactly??
Re: ZEX dry kit on d16z6 (knightnam)
Fuel pump is pretty much necessary to run a 75 shot dry with the ZEX kit. It relies on increasing fuel pressure to add fueling so make sure to get the Walbro 255lph high pressure fuel pump. Start out by retarding timing 4 degrees.
