Help, Yellow specs on Plugs?
Old Jun 26, 2004 | 02:53 PM
HondaAccordSiR's Avatar
Default Help, Yellow specs on Plugs?
Tiny yellow specs on spark plugs, Zex Hyperformance plugs.
Someone verify this for me, I believe that means I'm burning up some aluminum or the internals itself. Most likely running lean or could it be a timing issue? I cannot adjust the timing of the car due to 03 Accord, coil on plugs, no dist here.
nitrous application. I'm going to back down the shot and I have a GReddy fuel pressure gauge now to monitor it. I'm also hitting a dyno to check if I'm running lean or not next week.
I pulled those Zex plugs out and put back the stocker Iridium plugs.
Old Jun 26, 2004 | 03:08 PM
Jared's Avatar
Default Re: Help, Yellow specs on Plugs? (HondaAccordSiR)
ditch the zex plugs. total crap.
Old Jun 26, 2004 | 03:44 PM
Default Re: Help, Yellow specs on Plugs? (Jared)
I agree, the car had a small spit here and there at idle, now its smooth.
my problem is I cannot find that stock iridium plug two steps colder. anyone got an idea NGK: IZFR6K-11, I would want a IZFR8K
sting94112
Apr 18, 2004 04:26 AM
Drew Peacock
Oct 21, 2003 10:25 PM
