HELP!! Turbo install finished. UBERDATA BIN HELP!
I will be running Uberdata. Can someone check my basemap, to see if I can use this to run and startup my car correctly? I will use uber datalogging for now. Until I get it street tuned later on this week. (1.75 bar Map enough for 7lbs?)
http://mywebpages.comcast.net/...c.BIN
Whats been change from stockp72 basemap.
Vtec up to 4912rpm all across.
Fuel Mod TPS/Cold/Main all set to 58 - Enabled
Injector Calculator set to 460cc
What else should I do on my UBER bin file to run my setup? Running a little rich will be fine. I have to start from somewhere in order to get it Tuned right? So why not start a rich basemap and work from there on the wideband.
Heres my setup:
Turbonetics t3t04e 57/63
SSauto Tubular Manifold (5 Bar Braced)
Tial 38mm .5 WG (7lbs psi)
Greddy Type S BOV
3" Magnaflow, Resonator & Downpipe
Custom FMIC 25x7x3*2 1/2" inlet/outlet
Custom FMIC 2 1/2" pipings
p72 ECU w/OBD1 Harness (Sportin UBER!)
460cc Injectors
NGK bkr7e Plugs (gapped .30)
B&M Regulator
10w-30 Mobile 1 Full Synth.
Heres my setup:
Greddy Type S BOV
460cc Injectors
B&M Regulator
you didn't even set the boost portion, dont drive it until you click the apply button on boost fuel eff and boost ign retard on the boost tab. follow the steps in the How-to make a basemap in the uberdata forum.
ok whose willing to answer some questions pertaining to uberdata that i couldnt get answered at that forum? please lemme know.
thanx
dan
thanx
dan
PINKS
12
May 23, 2006 06:31 PM
AspectIndustries
Apr 25, 2004 09:08 AM
