4 puck or 6 puck clutch? Help me decide on a beefy clutch.
I have always been a fan of ACT clutches. I peaked out my old one that was rated at 386ft-lbs, so now it's time to get a better one. The new set-up should have around 550whp and around 450ish ftlbs of torque.
I am looking at running the ACT-HA3-XTR4 or the XTR6. It comes with the xtreme pressure plate, 4 puck or 6 puck racedisc, release bearing, & alignment tool. This clutch offers 494LBS of Torque.
This car will see the track, but not on a weekly basis. It will be street driven probably 4 days out of the week. So with that said, I should probably go for the 6 puck since it does not engage as hard as the 4 puck does. Also, do any of you run this clutch and have any feedback on it? I would love to have a tilton, but those are a little out of my price range right now.
Also, I tried searching but I'm on a 56k connection. So don't flame and tell me to search
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (PrecisionH23a)
im running the act 6 puck unsprung clutch disc with a heavy duty PP. the clutch feels like a stock clutch. i am upgradig to the act 4 puck with xtreme PP.
only thing i dnot get is why on ACT site is teh 4 puck clutch disc cheaper than the 6 puck disc.
any thoughts?? is the 4 puck better than the 6 puck? or vice versa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I have always been a fan of ACT clutches. I peaked out my old one that was rated at 386ft-lbs, so now it's time to get a better one. The new set-up should have around 550whp and around 450ish ftlbs of torque.
Also, I tried searching but I'm on a 56k connection. So don't flame and tell me to search </TD></TR></TABLE>
Precision, I was in the same boat as you. I am a huge ACT fan as I have yet to see one fail in my "posse" of friends and we all use them. I beat my XTSS to death and it held fine forever and was still good when I pulled it out. In preparation of the new build I bought the Xtreme 6 puck setup. It is a "different" clutch in that it grabs MUCH harder I think. It has a little chatter but nothing I didn't expect nor is it that bad. Mine isn't a daily driver car so I wasn't too worried.
I say go for it. Don't mess with the HD pressure plate though. It sounds as though you need the Xtreme one.
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (NextelBuddy)
less material. cheaper to make? just look at the ratings, i think they are rated the same. i think either or, but thats me.
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (ladysman)
Thanks for the info
I ran the XTSS on my old set-up and I am actually going to run it on a customers prelude that is going to see a 100 shot now... but lots of boost later. The 4 puck and 6 puck are both rated at 494ftlbs, the only logical reason for the 6 puck being more is it requires more machining and material. Makes sense.
I guess I'll give the ha3-xtr6 a try unless anyone has any other interesting information to add in.....
have u looked or anyone into clutch net systems...price is better and seem to have same quality fo product... except they have dual diaphram in there pressure plate.
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (CUSTOMCONNECTION)
I would recommend the 6 puck with the Xtreme pressure plate. I ran a 4-puck before in an H23vtec del sol and it was horrible. Definitely nothing like the clutchmasters 4-puck and alot harsher than the act 6-puck. I am currently running an ACT xt/6puck in my ls-t 4-door and have loved it so far. Also remember that ACT released the Maxx Extreme pressure plates as well. Kinda gives you another option
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (JDMH22HATCH)
XTR6 here... daily driven. haven't put it to any harsh use but it's fine for daily driving if u know how to drive and don't mind occasional chatter, then again this is my 2nd 6 puck clutch.
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (CivicRyda2k)
btw... the engagement/chatter/pedal pressure gives me confidence that sob will hold. i've been thru 2 other clutches and this one feels manly
I did not know about the maxx xtreme pressure plate. I'll have to call ACT on monday and find out a little more about them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I did not know about the maxx xtreme pressure plate. I'll have to call ACT on monday and find out a little more about them.</TD></TR></TABLE>
I have talked to ACT about the Maxx and they told me it can't be used on the street. That was 4 months ago, although they don't even make one for mine.
I would be curious to hear what they say.
I think you can get the max pp but if you get a 6 or 4 puck, you NEED to have a dogleg tranny.
Re: 4 puck or 6 puck clutch? Help me decide on a beefy clutch. (TwoK4drSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoK4drSi »</TD></TR><TR><TD CLASS="quote">I think you can get the max pp but if you get a 6 or 4 puck, you NEED to have a dogleg tranny. </TD></TR></TABLE>
My buddy ran the Maxx PP with the ORganic street disc in his car for some time. Made over 400whp daily driven and never had a problem
**** ACT , ACTION all the way, try flat shifting without a dual diaphram 3000lb p/plate. Its the P/plate that will let go. I run the 6 puck kevlar and its pretty nasty on the street I have a cable clutch.. But I know it will not slip.
chunky
16
02-25-2007 09:40 AM
