how much boost should i run?
Old Sep 25, 2004 | 04:09 PM
brasilianstreet's Avatar
Default how much boost should i run?
I got a b18b 94 ls engine in my eg coupe and im gona boost it but i have arias forged low compression pistons new and crower rods all new ready to be put in my car to handle more boost but i was wonderig should i put them in now if im jus gona run a fmu which i can only go 12lbs or should i jus go ahead and put the pistons and rods in anyways? because for me to go higher then 12 lbs of boost i need some kind of tuning right like uberdata or hondata?
Old Sep 25, 2004 | 04:54 PM
Drew Peacock's Avatar
Default Re: how much boost should i run? (brasilianstreet)
Why build your engine then run a FMU? You need to state what size turbo your running, just get the better EMS. I know some people get results with a FMU but is not really the smart option. To answer your question 6psi
Old Sep 25, 2004 | 06:13 PM
SlowGreenEJ's Avatar
base your decision off of what you put down to the wheels, not psi...You could be running 5-9 psi on a motor and be putting down 250whp on both levels of boost.
FONK
Sep 20, 2005 09:57 AM
The DX Rex
Dec 17, 2004 06:34 AM
Nikoli
May 30, 2004 07:31 AM
808b18c1boosted
Dec 19, 2003 04:08 PM
GZERO
Sep 16, 2002 12:42 PM
