D16 bottom end question
Old Sep 23, 2004 | 01:44 PM
VitaminD's Avatar
Default D16 bottom end question
At what point do the stock sleeves give up?
Right now my setup is the following:
d16a6 bottom end
custom JE .030 overs 9.0-1
eagle rods
d16z6 head
crane street/strip cam
and I am planning to try and boost 15 psi
I am trying to get to 250 to 300 hp
and I don't know if I am going to pop the block or not...
Thanks people...
D
Old Sep 23, 2004 | 01:51 PM
RyanEJ8's Avatar
Default Re: D16 bottom end question (VitaminD)
With proper tuning they can hold well over 400whp.
Old Sep 23, 2004 | 01:54 PM
dr_latino999's Avatar
Seriously? The stock sleeves as in the ones created umpteen years ago?
<Well, My bad, I didn't look at the creds on the response>
Old Sep 23, 2004 | 02:03 PM
RyanEJ8's Avatar
Default Re: D16 bottom end question (dr_latino999)
umpteen years ago?
Old Sep 23, 2004 | 02:29 PM
gtfourmn's Avatar
Nice setup. I don't know much on D stuff, but based on what I read on ht you should be fine for your goal.
Old Sep 23, 2004 | 05:54 PM
Johnyquest's Avatar
Default Re: D16 bottom end question (turbine)
Sleeves barely ever break unless you detonate... and even still you most likely break other things before sleeves. Not to say it doesn't happen, but you can build a motor without ever thinking about the sleeves if they are in good condition, and make 4-500 hp with the stockies. There is a post thats up right now, actually, about someone selling a teggy (white, it's doing a burnout in the pic on the thread, just read it a few mins ago) that is making 500? or so on stock sleeves.
So in sum: Don't sweat it.
Matt
Old Sep 23, 2004 | 06:05 PM
VitaminD's Avatar
Default Re: D16 bottom end question (Johnyquest)
thanks a lot
boondocks1805
Aug 23, 2008 09:35 PM
luder2_2vtec97
Aug 18, 2006 06:16 AM
mawkiemarc
Sep 28, 2005 05:43 PM
Boost_jnky
Apr 29, 2005 04:41 PM
Ya@inlinePRO
May 17, 2003 07:57 PM
