Crx turbo EMS?
Crx turbo EMS?
I really would like to run the aem ems in my car do I have to switch to obd 1 or can i run it obd 0 please fill me in with all info needed thanks
Re: Crx turbo EMS? (turboZChatch)
You have to switch to obd1 but you can run your obd0 dizzy if you want.. But I would just get the obd1 dizzy since it will make everything eaiser..
Convert to odb1...its easy...just do a little research and you could do it yourself....if you buy a conversion harness already done from someone then its even easier...
Re: Crx turbo EMS? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">You have to switch to obd1 but you can run your obd0 dizzy if you want.. But I would just get the obd1 dizzy since it will make everything eaiser.. </TD></TR></TABLE>
Umm... you can't stick wtih the OBD0 distributor as far as I know. You have to get the OBDI as the # of teeth on the wheel is different. Unless there's some way to install new wheel or something?
Re: Crx turbo EMS? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">
Umm... you can't stick wtih the OBD0 distributor as far as I know. You have to get the OBDI as the # of teeth on the wheel is different. Unless there's some way to install new wheel or something?</TD></TR></TABLE>
You can change the # of teeth with the AEM EMS.. You can run a damn ford dizzy if you wanted to, it doesnt matter..
Re: Crx turbo EMS? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">They have a racing EMS that has a generic connector if you want to wire up your own harness </TD></TR></TABLE>
Thats cool and all but even if they dont have an application for a certant car, you can just get one for a 92-95 civic and get a civic ecu harness and save yourself alot of money
You can change the # of teeth with the AEM EMS.. You can run a damn ford dizzy if you wanted to, it doesnt matter..</TD></TR></TABLE>
Yup, you're entirely right... thanks
Yup, you're entirely right... thanks </TD></TR></TABLE>
Gotta love the AEM EMS..
Re: Crx turbo EMS? (Tyler H)
Thanks alot guys I had the emanage but didnt really like it too much in my hatch so with the crx I am going with the aem I will buy the jumper harness and convert to obd1 I know how to convert and it is pretty easy so thats no big deal but thanks for the help
