Is tt ok to run 18 lbs on a fairly stock head??
ok i got a fully built bottom end but a igot a b16 head with port and polish on it, with all GSR internals, now is it ok to run 18 lbs on thta kinda head?? if not should i get springs and retainers? or just aftermarket valves?? let me knwo please thanks
Re: Is tt ok to run 18 lbs on a fairly stock head?? (BuiltTurboCoupe)
I have a stock GSR head with 80k miles, and my rev limit is set to 8500rpm's. Granted I don't rev that high everyday, but I do make max power at 8200.
The amount of boost you run won't weaken the head at all, but the stock porting will just become a limiting factor when you get into the 500+ range.
Re: Is tt ok to run 18 lbs on a fairly stock head?? (m R g S r)
I would at a minimum replace the stock retainers with titanium. I had a stock retainer let go in my Type R head. It took my complete head and my 2.0 liter C5 block with it.
