What Compression Pistons??
Old Sep 21, 2004 | 09:19 PM
B00ST2nR's Avatar
Default What Compression Pistons??
I need to purchase a set of Forged pistons for my FI setup. Lookin into CP pistons, but not sure what Compression to go with.
First off, I have a GS-R (B18C1). I'm also putting in a Cometic 0.120" Head Gasket which will lower my Compression Ratio to 8.2:1 cuz it's so thick.
Now should I go with 9.0:1 Pistons or 9.8:1 Pistons?
Another quick question...
So if I get 9.8:1 Pistons and put the Cometic 0.120" head gasket in, how low will my Compressions Ratio be around? What about with 9.0:1 Pistons?
Old Sep 21, 2004 | 10:49 PM
B00ST2nR's Avatar
Default Re: What Compression Pistons?? (B00ST2nR)
Old Sep 21, 2004 | 10:58 PM
Nikoli's Avatar
**** the headgasket and just get 9:1 pistons
Old Sep 21, 2004 | 11:59 PM
threatcon13's Avatar
New User
Default Re: What Compression Pistons?? (Deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">**** the headgasket and just get 9:1 pistons</TD></TR></TABLE> agreed
Old Sep 22, 2004 | 12:29 AM
project dc2's Avatar
Default Re: What Compression Pistons?? (Threatcon13)
run an OEM gasket and jus get 9:1 pistons.
Old Sep 22, 2004 | 07:48 AM
B00ST2nR's Avatar
Default Re: What Compression Pistons?? (project dc2)
hmmm... why not both? The Head Gasket AND some Forged Pistons? I would use an OEM HG, but I already spent $120.00 bucks on this Cometic HG. They told me it would be great for Boosted applications.
Old Sep 22, 2004 | 07:55 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">hmmm... why not both? The Head Gasket AND some Forged Pistons? I would use an OEM HG, but I already spent $120.00 bucks on this Cometic HG. They told me it would be great for Boosted applications.</TD></TR></TABLE>
Why both? A thicker headgasket destroys your quench, messes with your cam timing, and is more prone to blow out because it's thicker. Running 9:1 Cp pistons and a .12" cometic will result in 7.6:1 compression. Running 9.8:1 pistons and a .12" cometic will result in 8.2:1 compression. That 8.2:1 with the massive head gasket will probably handle as much boost and power on pump gas as a 9:1 motor with a stock thickness headgasket. Return or sell the headgasket, run some 9:1 pistons, and be done with it. A thick headgasket just adds too many headaches, especially if you're going to run low comp pistons anyways.
Old Sep 22, 2004 | 09:02 AM
B00ST2nR's Avatar
Default Re: What Compression Pistons?? (Chip)
Thanks for the info fellas.
Old Sep 22, 2004 | 09:04 AM
fast94ex's Avatar
You could just mill the head to get the compression where you want it.
Old Sep 22, 2004 | 02:05 PM
Default Re: What Compression Pistons?? (fast94ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast94ex &raquo;</TD></TR><TR><TD CLASS="quote">You could just mill the head to get the compression where you want it.</TD></TR></TABLE>
that just makes **** complicatd. keep it simple.
Old Sep 22, 2004 | 02:50 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
that just makes **** complicatd. keep it simple. </TD></TR></TABLE>
Yep.
I just got myself some 9:1 CP Pistons with Eagle Rods. I'll be using a stock Head Gasket.
kevin7200
Jan 12, 2015 08:18 PM
kam 94' DC2
Apr 13, 2010 06:57 AM
NathanMorris
Jul 28, 2006 05:59 PM
Killer_B
May 29, 2003 07:03 PM
jetdriven
May 6, 2002 06:44 AM
