Finished Install (lots of pics)...Oil Leak Advise???
Guest
Posts: n/a
Well i finally got around to finishing my 92 hatch. Im pleased with everything except i can't get rid of this damn oil leak. The Pan is a brand new OEM piece. Maybe ive forgot how to install an oil pan but i can't get this thing to seal (tried 3 times ) any tips?....anyways heres some pics of everythign completed...enjoy
(ignore the disgusting looking stock cam gears.... )
Guest
Posts: n/a
Re: Finished Install (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">Looks excellent, blue cam gears will set that off real nice.
That car should move!</TD></TR></TABLE>
like this huh ( I pulled them off because i could NOT get my timing correct with them..i dont 'know if the marks are off or what )
Guest
Posts: n/a
Re: (djfob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djfob »</TD></TR><TR><TD CLASS="quote">Did you use a new gasket? If you did all you can really do is try some rtv sealant.</TD></TR></TABLE>
yup new gasket, new pan, tried once with sealant, once without...still leaks...
Guest
Posts: n/a
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Hmm, wonder if the pan, bent and isn't sitting flush on the bottom of the motor, put some massive RTV on both sides of the gasket and see if you can get it to seal. That is a pain in the ***.</TD></TR></TABLE>
tell me about it...
tell me about it...
Re: Finished Install (lots of pics)...Oil Leak Advise??? (Mpir3)
How safe is it to mount the fpr to the rail like that? Wouldn't to much vibration maybe crack the adapter or something causing it to break off?
I wanted to run it like that aswell but decided to run it to the firewall.
Re: Finished Install (Rocks)
There are two metal washers on the tranny side studs that are built into the gasket. Sometimes when you take off a gasket they tend to stick around the studs which will leak when you put a new gasket on.
Guest
Posts: n/a
Re: Finished Install (Boosted_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_LS »</TD></TR><TR><TD CLASS="quote">There are two metal washers on the tranny side studs that are built into the gasket. Sometimes when you take off a gasket they tend to stick around the studs which will leak when you put a new gasket on. </TD></TR></TABLE>
lol we have a winner
pulled the pan back off late last nite and found not only 1 but 2 old washers stuck on 1 of the studs. I never knew about this before as on my old car i always used cheap napa gaskets (no metal washers)...anyways the new gasket should be here in the morning and hopefully she'll be good to go
Guest
Posts: n/a
Re: Finished Install (EM1 MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 MIKE »</TD></TR><TR><TD CLASS="quote">Wow very nice setup. Full-Race as usual. </TD></TR></TABLE>
thanks...should have her street tuned tomo and on the dyno within a few weeks ( gonna keep it @ 11-12psi untill spring...hoping for 300whp @ those levels)
Guest
Posts: n/a
Re: Finished Install (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">ncie set up, who coated the manifold looks sooooo sweet</TD></TR></TABLE>
Local place up here, they just started doing it...i was excited, saved me ~$100 bux
J1A1H
07-06-2006 07:06 AM
Shakes
09-25-2004 05:52 PM
Dan GSR
09-11-2003 10:51 PM
