Does anyone have a sound clip of detenation I can't spell.....
I've read what it says on how it sounds but I can't tell if thats what it is or if it is just rocks under my car since I live on a loose gravel road. I know I sound like a damn noob with this one but... I need some help
Re: Does anyone have a sound clip of detenation I can't spell..... (FOrSfEd)
tick, tick, tick....
It sounds like little rocks hitting your fenderwell...coincidentally
Re: Does anyone have a sound clip of detenation I can't spell..... (boost psycho)
damn sounds like thats what I heard. Luckily I didn't mess anything up. Any suggestions on fixing this for the moment, until I can get it tuned. what kind of plugs are you running and what are they gapped at.
Re: Does anyone have a sound clip of detenation I can't spell..... (Matgallis)
sounds like a small chain slapping against the exhaust, try boosting the octane on your fuel, retarding the timing alittle untill you get it tuned, on a boosted motor i would go 9 series plugs.
Re: Does anyone have a sound clip of detenation I can't spell..... (Mase)
definately sounded like rock pebbles in an aluminum can being shaken.
heard that once on a hot day untuned.
Re: Does anyone have a sound clip of detenation I can't spell..... (Jeffescortlx)
Yeah, I mean the whole road isn't gravel, but of course you will have loose gravel in certain places.
i have that same problem when im in low rpms in a higher gear and i try to accelerate y putting the gas to the floor.
Re: Does anyone have a sound clip of detenation I can't spell..... (TurboChrgd_Civic)
Yeah I believe mine is also at low rpm in high gear. But I check my plugs and I see no white spots and what not on them so could that still be detonation or how ever u spell it
Re: Does anyone have a sound clip of detenation I can't spell..... (9sech22civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic »</TD></TR><TR><TD CLASS="quote">sounds like a small chain slapping against the exhaust, try boosting the octane on your fuel, retarding the timing alittle untill you get it tuned, on a boosted motor i would go 9 series plugs.</TD></TR></TABLE>
I hope you meant 7 series not 9. NGK BKR7E
Re: Does anyone have a sound clip of detenation I can't spell..... (underpressure02)
I use the 7 seris right now, I have them gapped at .30 should I lower the gap to .28
no i meant a 9 series, it is a colder plug and will be a more comfortable to take the car to the tuner, after that 7 series is fine if your boosting under 12.
