Plx wideband help!!!!
Old Sep 25, 2004 | 07:47 AM
boosted-delslow's Avatar
Default Plx wideband help!!!!
I just put my plx m-300 wideband in and it will not turn on when I turn on the key. I hooked into a keyed source in the fuse box. I just have to hook up the red and the black wire because I am going to use my factory o2 sensor and the plx o2 sensor so I dont need the white and the gray wire right????
Old Oct 3, 2004 | 04:16 PM
99lspwr's Avatar
Default Re: Plx wideband help!!!! (boosted-delslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-delslow &raquo;</TD></TR><TR><TD CLASS="quote">I just put my plx m-300 wideband in and it will not turn on when I turn on the key. I hooked into a keyed source in the fuse box. I just have to hook up the red and the black wire because I am going to use my factory o2 sensor and the plx o2 sensor so I dont need the white and the gray wire right????</TD></TR></TABLE>
Your a dumbass..Sell the del-sol and buy yourself that dream car...(87 iroc w/305 tpi).......hahahahahahahahahahahaha.....
Old Oct 7, 2004 | 04:32 PM
g2_boosted's Avatar
Default Re: Plx wideband help!!!! (importjunk)
Make sure you are actually getting power and u have a good ground, I hooked mine up the other day and all i did was tapped into a keyed power source and a basic ground and it automatically turned on.
neli_nael
Apr 20, 2008 05:30 PM
dc4drewH
Aug 17, 2006 09:02 AM
ScottEK
May 11, 2004 02:31 PM
Slow96RedEk
May 16, 2003 08:10 PM
HXMan
Apr 26, 2002 08:13 AM
