what turbine should spool faster?
what turbine should spool faster and have the least amount of back pressure?
t3 .63 a/r
t3 .82 a/r
t4 .58 a/r
t4 .68 a/r
assuming the compressor side is a sc61, what would you select for a semi reponsive street car with big top end power?
9:1 b16 9200 redline
t3 .63 a/r
t3 .82 a/r
t4 .58 a/r
t4 .68 a/r
Re: what turbine should spool faster? (Boostage)
What size wheel! why does everyone on H-T ignore this!
T3 could = stg 1, stg 2, stg 3, or stg 5? and I think Precision or ITS has a stg4
T4 I don't know **** about and is probably too big anyway.
I would guess you would want the stg 3 T3 in a .63 housing. Your first sentence makes no sense. Response and flow are enemys in turbine selection, you are trying to find a happy medium.
Re: what turbine should spool faster? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">
Your first sentence makes no sense. Response and flow are enemys in turbine selection, you are trying to find a happy medium.</TD></TR></TABLE>
what are u talking about? backpressure will always exsist unless u have open 4 inch downpipe. I guess since backpressure also affects spool time, then the way i worded the question makes it sound redundant.
Re: what turbine should spool faster? (RedStarGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr »</TD></TR><TR><TD CLASS="quote">t3 63 ar</TD></TR></TABLE>
even fastr than a t4 with .58?
A T3 .63 with a stage 5 wheel will come on faster than a t4 .58. My vote goes for a t3 .63 stage 5 mated to a sc61. Its the exact turbo I went back to from my pt67 T4 .58. I would go with that unless you want more than 550whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">
what are u talking about? backpressure will always exsist unless u have open 4 inch downpipe. I guess since backpressure also affects spool time, then the way i worded the question makes it sound redundant. </TD></TR></TABLE>
I'm talking about helping you find a turbine (restriction) that will meet your needs (spool time/power). Forget about the DP and exhaust. we are talking about turbine selection. If you don't realize how choosing the turbine is a compromize, how the hell did you come up with the options you listed, which really aren't options anyway because you circumvent the most importent spec, wheel size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">what turbine should spool faster and have the least amount of back pressure?
t3 .63 a/r
t3 .82 a/r
t4 .58 a/r
t4 .68 a/r
9:1 b16 9200 redline</TD></TR></TABLE>
The quicker the spool the more the backpressure. The slower the spool the less backpressure. A T4 exhaust side even with a P-trim wheel is way overkill for a 1.6L honda thati s going to be driven on the street.
t3 .63 a/r
t3 .82 a/r
t4 .58 a/r
t4 .68 a/r
Re: what turbine should spool faster? (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">I always wondered which of these two would spool faster.
Stage 5 .63 Turbine vs Stage 3 .82 Turbine
I would guess the stage 3. From what I have read, assuming those two sizes are very close, you would want to pick the bigger wheel and lower a/r. Unfortunately I don't know the rational behind this so I have no real tech to add. maybe someone can fill us in...
