Can I run a stock Rad.
I have an 89 CRX with a b16/turbo. I need to buy a new radiator so the manifold will fit without any interference. Can I get away with a oem civic radiator or do you suggest I go with an aluminum one? Thanks!!
If I were you Id probably just go with the OEM radiator cuz you can probably pick one up used for cheap, and its not really necessary to upgrade. Youll probably need a slim fan though.
