high compression numbers but...
hey guys,
another quick question for you guys. i tried searching..but when u search compression test...u get alot of results..
anyway...my compression used to be 230 across the board naturally aspirated.
after 2 months of running turbo..my compression reads... 230/230/230/205
i pour a cap of oil in cylinder 4...and it jumps to 235.
should i start getting worried?
thanks in advance
thanks in advance
its only an 11 percent gap..Usually not to bad I think if it is more than a 20 percent gap then you should start to worry. Id still keep an eye on it.
why are the numbers still over 200?
i just did another compression..and it hit 230. but maybe i didn't burn off the oil i poured in from yesterday's test. id unno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Isnt it that its suppose to be no more than roughly 20 pts difference between cylinders? not 20%... I would get ready to do a rebuild personally.</TD></TR></TABLE>
i guess its time for a leak down test. this sucks.
jeffcat
Dec 16, 2013 07:41 AM
