Studs, bolts, and other random parts for turbo....Where to buy?
I need like a couple studs for my 4 bolt flange for the DP. I also need so for the WG flange. Should I go to Homedepot and get some. If so, what kind? Hardened steel right? Thanks again!
Re: Studs, bolts, and other random parts for turbo....Where to buy? (adseguy)
Check out your local hardware store. Home Depot doesn't have a great selection of metric bolts/studs.
A local hardware store with the "Hillman" fastener supply system. In IL, I know the Do-It Best hardwares and maybe ACE hardware stores have them.
Metric automotive studs 8mmx1.25, the right length stud cost $1.95 each
There is a Do-it Best store in
Builders Supply Co.
40 North Ave.
Aurora, IL 60505
1-630-897-4204
Wannemakers
1940 Ogden Avenue
Downers Grove, IL 60515
1-630-852-0700
Century Maintenance Supply
1 Gateway Court Unit B
Bolingbrook, IL 60440
1-630-633-5500
Builders Supply Co.
40 North Ave.
Aurora, IL 60505
1-630-897-4204
Wannemakers
1940 Ogden Avenue
1-630-852-0700
1-630-633-5500
Re: Studs, bolts, and other random parts for turbo....Where to buy? (BROOD)
Re: Studs, bolts, and other random parts for turbo....Where to buy? (hondaguyef)
I got all of mine from flamenco-t on here, stan was nice and got me all the misc parts I needed.
Re: Studs, bolts, and other random parts for turbo....Where to buy? (silverb18)
I bought some studs from the Honda dealership. The ones used used to hold the exhaust manifold to the head fit. They are a little pricey at 2 dollars a stud but you have the peace of mind knowing they were intended for high temps.
descartesfool
07-11-2010 10:26 PM
