Are all the Greddy 18G's for the DOHC kits the same?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'm wondering if all the Greddy 18G's from the DOHC turbo kits are the same, for example, the one from the B16 kit being the same size as the GSR kit/LS kit, etc.
The reason I ask is I have a greddy SOHC 15G kit right now on my D16Y8, and I have a friend who's got a blown 18G turbo for sale. Problem is, he's got a H22 greddy turbo kit.
Is the 18G from the prelude kit a different trim than the ones from the Si, GSR or LS?
Let me know, I've got plans for a fun new project (hint: 18G w/external gate (Tial 35mm)bolted onto my 15G manifold, 17-18 psi, built SOHC motor, 350whp )
Re: Are all the Greddy 18G's for the DOHC kits the same? (boostincoupe)
Not sure but i think the only diffrence is the piping and the blue box if you have the old kit other then that it should be the same im using a si kit on my gsr
Re: Are all the Greddy 18G's for the DOHC kits the same? (tegon-gsr)
perfect, so if I get this 18G turbo they're all the same then? I mean, the ones for the Honda kits?
Turbo should be the same. Fitment may be tough because of different manifold flange angle.
Search on turbod16.com as a how to's been done about this...
Re: Are all the Greddy 18G's for the DOHC kits the same? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">I thought that the b16 kit came with a 16g, i could be wrong.</TD></TR></TABLE>
The B16 kits come w/ the TDO5H-18G also. As for the Prelude, i believe it comes w/ a TOD05/6H-18G or something like that...
at the jetties fishin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
Let me know, I've got plans for a fun new project (hint: 18G w/external gate (Tial 35mm)bolted onto my 15G manifold, 17-18 psi, built SOHC motor, 350whp )</TD></TR></TABLE>
what exactly are you going to do? weld the wastegate to the cast manifold??
Re: Are all the Greddy 18G's for the DOHC kits the same? (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">
what exactly are you going to do? weld the wastegate to the cast manifold??</TD></TR></TABLE>
Yes. H-T user ccfries did it no problem with his ITR. 35mm Tial WG welded to a greddy manifold.
295whp/222tq
295whp/222tq
TD05H-18g
trims:
76.1 turbine
55.6 compressor atleast that is what turbo mag said about it in 2000 when they did a test on it
trims:
76.1 turbine
sinister357
09-12-2007 06:51 AM
Nocturnal
09-23-2003 05:51 PM
boostincoupe
08-28-2002 05:23 PM
