exedy clutch juddering
Just fitted the my built motor with new exedy clutch plate and cover and refaced flywheel and now apart from leaking oil every time I pull away from a stand still it judders like hell till I give it some more gas.
Can you give me any ideas on wants making this happen.
Thanks
Thanks
Re: (NOSED_CRX_VTEC)
i'm experiencing similar problem like you.
i got an exedy organic clutch, exedy pressure plate and a new release bearing. the flywheel wasn't resurface but i did break in the clutch for 600km. this was installed on february 2004 and about 3-4 months after, the clutch started to chatter/judder when i pull away from a stand still. this only happens when the engine is cold but after about 15mins of driving the chattering/juddering goes away.
i replaced the clutch master and secondary but it didn't help.
i noticed that whenever i drop hard with boost then parked the car til the morning the chattering/juddering goes a way a day or two then comes back. but i've yet to do more driving hard at night to see if it is just a coincidence or not.
its getting annoying and i took it to a mechanic who refused to open it saying that honda flywheel are strong and not easily warped.
anyway, did you try adjusting the clutch?
SSJSubgeta
10-22-2005 12:20 PM
EVOCELICA
10-13-2001 11:36 PM
