About to go tune for first time.
I know to have gas, just changed oil, putting new plugs in tomorrow. Is there anything else I should could do before I go? May seem like a silly question, but I'd hate to get up there and then find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grndcont »</TD></TR><TR><TD CLASS="quote">tyre pressure,.</TD></TR></TABLE>
No tire pressure adjustment required on a Dynapack. The wheels are coming off anyway.
I dynoed at 208HP and 178.4 lbs of torque. He said my stock exhaust is choking the turbo, and that I need bigger injectors(I'm only running 310ccs). He thinks with bigger injectors and exhaust I can hit 250hp. As for the dyna pack, it was actually pretty cool. How better to measure power to the wheels than having your car bolted into the machine, no wheel hop.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SdGSR01 »</TD></TR><TR><TD CLASS="quote"> I dynoed at 208HP and 178.4 lbs of torque. He said my stock exhaust is choking the turbo, and that I need bigger injectors(I'm only running 310ccs). He thinks with bigger injectors and exhaust I can hit 250hp. As for the dyna pack, it was actually pretty cool. How better to measure power to the wheels than having your car bolted into the machine, no wheel hop. </TD></TR></TABLE>.
How much boost?
Numbers look good for stock exhaust
How much boost?
I hit close to 8psi at 4500 RPM and then it drops after that. The numbrs look good, just sucks because all I see when I look at that dyno sheet is "Buy an Exhaust and Injectors" even dreamed about it last night
ITR.#1446
Mar 25, 2004 01:02 PM
