wierd timing problem , please help.
Old Sep 23, 2004 | 03:43 AM
ATS*Mark's Avatar
OG triple OG
Default wierd timing problem , please help.
ok im running uberdata , and i have my ignition timing set to 16 degrees on my chip . this is on a 2000 d16y8 . when i try to set my timing at the dizzy , with the timing full advanced at the dizzy im only getting to the TDC mark on the crank pully . why is this happening?
Old Sep 23, 2004 | 06:11 PM
ATS*Mark's Avatar
OG triple OG
Default Re: wierd timing problem , please help. (Hella_JDM)
up
Old Sep 23, 2004 | 08:03 PM
Devine's Avatar
I had the same problem on my d15b, before tuning I attempted to set the timing to stock, with the distributor fully advanced it was still 1* retarded.
Old Sep 23, 2004 | 08:09 PM
honda9369's Avatar
**** im having the same problem. that and now a new one. i put the jumper wire in set it to lets say stock. when i pull the jumper out it will go bad to a adv setting.wtf
Old Sep 23, 2004 | 10:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: wierd timing problem , please help. (Devine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devine &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem on my d15b, before tuning I attempted to set the timing to stock, with the distributor fully advanced it was still 1* retarded.</TD></TR></TABLE>
what did you do to fix it?
Old Sep 23, 2004 | 10:56 PM
honda9369's Avatar
i didnt yet. this is a new problem
Old Sep 23, 2004 | 11:13 PM
ATS*Mark's Avatar
OG triple OG
Default Re: wierd timing problem , please help. (honda9369)
my **** must be really off because its linning up with the TDC marks , whats TDC on the y8 anyway, 10 degrees?
Old Sep 23, 2004 | 11:22 PM
honda9369's Avatar
mine is in the opposite direction
Old Sep 24, 2004 | 06:08 PM
ATS*Mark's Avatar
OG triple OG
up for more help
Old Sep 24, 2004 | 07:11 PM
honda9369's Avatar
t,t+t
Old Sep 24, 2004 | 07:28 PM
SOHC_MShue's Avatar
bump for running uberdata on a y8. Stock ignition timing is 12 degrees for the y8. Also you may want to look into subtracting 4 degrees everywhere on your ignition tables. I did anyways so i wasn't running 4 degrees too much timing.
Old Sep 24, 2004 | 11:25 PM
ATS*Mark's Avatar
OG triple OG
Default Re: wierd timing problem , please help. (SOHC_MShue)
ya im using beerbongs map , and i was under the impression that stock y8 timing is 14 plus or minus 2.
Old Sep 25, 2004 | 01:25 AM
94dxt's Avatar
could your cam timing be off, making the rotor pass the dist cap points @ the wrong time?
Old Sep 25, 2004 | 02:43 AM
ATS*Mark's Avatar
OG triple OG
Default Re: wierd timing problem , please help. (94dxt)
how would i check that??? could be a possibility
tctruong94
Apr 27, 2017 11:10 AM
Nataku
Dec 27, 2006 07:04 PM
doobiesack23
Jun 29, 2005 01:43 PM
