AVCR: Scramble Question
Old Sep 21, 2004 | 09:31 PM
Bulldogg83's Avatar
Default AVCR: Scramble Question
I searched already in the archived threads and didn't really find the answer I was looking for. When hooking a scramble switch up does the ground wire HAVE to be connected to the same ground wire that the AVCR is hooked up to or does it matter as long as it is grounded? I know that the Orange wire coming from the AVCR needs to be connected to the switch, but wasn't sure on ground wire.
Old Sep 21, 2004 | 09:42 PM
electric_rex's Avatar
Default Re: AVCR: Scramble Question (Bulldogg83)
any switch you try to attach will have 2 side one which will lead to the orange wire (scramble) and on the othe side you connect to any ground. i used the other horn button in my steering wheel. this way one button goes to the intercooler sprayer and the other goes to the scramble button. both being power adders, it kinda cool.
Old Sep 22, 2004 | 06:48 AM
White Smoke's Avatar
i my honda
Global Mod
Any GOOD ground should work
Old Sep 23, 2004 | 06:37 AM
Bulldogg83's Avatar
Default Re: AVCR: Scramble Question (si2die4)
UPDATE:
Well we got it to work, and for some reason hooking the ground wire up to the same ground as the AVCR did play a part. Before I had it grounded to where my boost and EGT gauges were grounded and the scramble setting wouldn't work, but then I spliced into the black wire that is the ground off of the AVCR and it works fine now.
epicbeats
Jul 29, 2009 12:59 PM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
GoT HaTcH
Sep 9, 2003 10:10 PM
hybridreams
Aug 10, 2003 06:22 PM
