Cometic Head gasket
Old Sep 25, 2004 | 12:37 PM
mrx's Avatar
mrx
Default Cometic Head gasket
Hallo,
i often read that ppl with high #'s use cometic head gaskets instead of the stock honda gaskets... can anyone tell me why the cometic gaskets are better then the stock gaskets?
Greets
Malte.
Old Sep 25, 2004 | 12:41 PM
11psiTurboSI's Avatar
Default Re: Cometic Head gasket (mrx)
if you have a stock bore... I'd just stick with a oem honda headgasket... there's alot of guys makin 400-550hp on oem headgaskets
Old Sep 25, 2004 | 12:46 PM
mrx's Avatar
mrx
Default Re: Cometic Head gasket (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">if you have a stock bore... I'd just stick with a oem honda headgasket... there's alot of guys makin 400-550hp on oem headgaskets</TD></TR></TABLE>
so the main difference is the bore size? or is the cometic gaskets are also stronger?
Thanks
Malte.
Old Oct 1, 2004 | 07:18 PM
95gsrturbo's Avatar
cometic gaskets are made thicker separating the head from the block a bit-- some up to 3mm therefore lowering compression and stress on the bottom end
this also is safer for detonation.
Old Oct 1, 2004 | 07:31 PM
MidShipCivic's Avatar
Of course there stronger why dont you compare materials...
Old Oct 2, 2004 | 06:58 PM
spooledex's Avatar
Some Cometic come with the hp rings too and help preload when you put on the head. Just better for higher boost levels I believe. I have gone with 3 of them on several setups. Never blew one and run high boost too. should be safe with a stock headgasket up to like 20psi. I have seen higher
Old Oct 2, 2004 | 09:08 PM
dornon13's Avatar
i was told that it is best to use these if you have a large bore such as 85 or anything much higher than stock cuz alot of other hg's are made from the oem gaskets just bored out...
cgaleema
Apr 28, 2011 04:52 PM
blackccoupe
Aug 27, 2008 08:52 PM
panda_eh2
Dec 12, 2007 01:35 PM
White91EF
Oct 6, 2007 03:30 PM
gowyeng
Feb 9, 2005 06:36 AM
