Problems with RC injectors opening?
Old Sep 24, 2004 | 09:57 PM
tub_sephiroth's Avatar
Default Problems with RC injectors opening?
Do RC injectors have a problem opening up at cold starts? As in previous threads that I've posted, I've been having problems with cold start misfiring. I'm using a VAFC II with it set at -18 @ 1k. When it warms up, it's fine but on cold starts, my car throws misfire codes.
I finally found a solution to this. I would set the the AFC at -10 @ 1k-1.5k, until the motor warms up a bit (about 2-4 minutes), then I just set it back to where it was before. No cel codes this way.
Anyone know if it's safe to adjust the AFC settings while at idle, or do I have to shut the motor off?
einzelherz
Jan 7, 2013 11:04 AM
gosu08
Jan 23, 2009 10:19 AM
EJ8 GSR-T
May 25, 2006 05:31 PM
td04civic
Sep 4, 2002 08:01 AM
