shaft play?
Old Sep 22, 2004 | 02:40 PM
AF-b16a1's Avatar
Default shaft play?
i just recieved a turbo from a fellow ht member...and i spund the turbine wheel and it seems like the wheel is loose...that is not good is it?
Old Sep 22, 2004 | 02:55 PM
USDM 4G VTEC's Avatar
Default Re: shaft play? (AF-b16a1)
if u hold one wheel from one side/ the other one still spins free???
they should be sstrong and move directly to ea other
Old Sep 22, 2004 | 11:15 PM
AF-b16a1's Avatar
they both move together....it just seem if i move the turbine the thing wobbles...the seller said that its normal cause its a big turbo (t3/t04e)...is he right?
Old Sep 22, 2004 | 11:28 PM
1CiViC1's Avatar
when you spin the shaft does the "blades" touch the housings? try the compressor side, do you hear a scratching sound?
Old Sep 22, 2004 | 11:30 PM
AF-b16a1's Avatar
no scratch noise
Old Sep 23, 2004 | 11:39 AM
AF-b16a1's Avatar
anyone?
Old Sep 23, 2004 | 01:20 PM
CalGSR99's Avatar
Default Re: (AF-b16a1)
They should move a little bit (very little) but the blades should not touch the housing (scrape). You could also check the exhaust or compressor sides for oil. I bought a turbo a while back and had no shaft play. When i took the exhaust housing off i noticed a bunch of burnt oil in there. Not good.
Old Sep 23, 2004 | 02:27 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: (CalGSR99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalGSR99 &raquo;</TD></TR><TR><TD CLASS="quote">They should move a little bit (very little) but the blades should not touch the housing (scrape). You could also check the exhaust or compressor sides for oil. I bought a turbo a while back and had no shaft play. When i took the exhaust housing off i noticed a bunch of burnt oil in there. Not good. </TD></TR></TABLE>
i bought a used turbo too and the wheels on the comp or turbine side takes me a little effort to make it spin. is it suppose to spin freely
Old Sep 23, 2004 | 02:38 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
The maximum shaft play tolerance limit (both axial and radial) is usually about .005" - .010", or about 1 or 2 sheets of paper thick. Be very wary when people say "little to no shaft play" because they are usually either clueless or full of ****.
Old Sep 23, 2004 | 03:24 PM
AF-b16a1's Avatar
thanks for the info...i think it does hit the sides a little
Old Sep 23, 2004 | 06:46 PM
i can turn the wheel w/ some effort of one finger but it wont spin freely is it suppose to do that?
Old Sep 23, 2004 | 08:45 PM
RockinSOHC's Avatar
if it hits the sides, turbo is no good. had the same problems on mine
F/S: Brand new Garrett T3/T04B turbo good for 400-450hp. Spools fast. $480+shippng
H-3 Trim
Ar. .48
Old Sep 23, 2004 | 08:46 PM
AF-b16a1's Avatar
Default Re: (RockinSOHC)
are you serious cause i just bought this turbo
Old Sep 23, 2004 | 08:49 PM
AF-b16a1's Avatar
yah and the shaft feels flimsy and one bolt is stripped
Old Sep 24, 2004 | 01:56 AM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinSOHC &raquo;</TD></TR><TR><TD CLASS="quote">if it hits the sides, turbo is no good.</TD></TR></TABLE>
that is correct! Basically a big paper weight now
Old Sep 24, 2004 | 04:11 AM
AF-b16a1's Avatar
Default Re: (1CiViC1)
i better be able to get my money back...
Old Sep 24, 2004 | 11:44 AM
RockinSOHC's Avatar
who ever sold you that turbo ripped you off!!!
had the same problem on mines and found out the bearings were shot, I had to get another turbo. Try to gert your money back ASAP
Old Sep 24, 2004 | 11:49 AM
turbodan4's Avatar
why did you have to get another turbo
why couldnt you have just gotten the turbo rebuilt
Old Sep 24, 2004 | 11:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
Before writing it off, you might want to have a professional take a look at it. It's very hard to describe over the internet what is and isn't good. Is there anywhere local to you that you could take the turbocharger to have someone look it over? A diesel shop or something?
Old Sep 25, 2004 | 10:50 AM
RockinSOHC's Avatar
getting my turbo rebuilt cost almost as much as getting a new one. I had to replace everything on my turbo, turbine wheels, bearings, bearing housing everything. Rebuilt kit for my turbo would've cost $380 and up, where I can just buy brand new one for extra cost and don't have to wait for the turbo to get back
Old Sep 27, 2004 | 04:16 PM
AF-b16a1's Avatar
the turbo has way to much play...the bearing would need to be replaced...this sucks...and the guy i bought it from said he wont give me my $ back...i am really pissed off
Old Sep 27, 2004 | 09:22 PM
RockinSOHC's Avatar
If your interested, I have a brand new garrett T3/T04B turbo thats good for 400-450 hp. Its a H-3 Trim and AR. .48. Spools fast. Asking $480 Brand New or Pick up. Got 2 turbos left. Let me know if your intersested.
Old Sep 27, 2004 | 09:52 PM
AF-b16a1's Avatar
i am more worried about getting my money back at the moment rather than spending some more...but thanks
Old Sep 27, 2004 | 10:05 PM
crispydee's Avatar
If its not been touching the casing, buy a rebuild kit and do it your self. You get the bearings seal etc and its easy to do. If you are carfull and mark the posistion of every thing you might get away with not having to rebalance it. would cost $60-80 depending on which rebuild kit you got and a day of your own time to take the turbo off rebuild it and put it back together. You even get the bolts to replace the snaped one. (if you can get it out)
onequickteggy
Aug 14, 2013 04:43 PM
SOHCvtakdude
Dec 8, 2010 02:41 PM
wpgcivic
Apr 21, 2006 06:10 PM
huge230
Mar 27, 2006 03:35 PM
yusoslo
Jan 10, 2004 08:44 AM
