My Solution to Charge pipe popping off.
Old Sep 25, 2004 | 11:45 AM
m R g S r's Avatar
Default My Solution to Charge pipe popping off.
Well I got sick and tired of the Charge piping coming off every other day after some hard boosting. I guess it was a combo of the engine moving backwards, pulling on the coupler and the boost which blew the coupler off.
I wasn't able to use T-bolt clamps on this section of the piping because it is somewhere around 2.75", and I only had 2.5" ones.
I got the supplies from a local hardware store for like $3. Here are some pics of what I did:
Now there is no tension on the coupler, and the coupler is there just to seal the piping. I went out for a long drive, boosted alot and it didn't budge, so hopefully it will hold up.
Old Sep 25, 2004 | 11:50 AM
johnmay19's Avatar
Default Re: My Solution to Charge pipe popping off. (m R g S r)
Interesting solution. Hope it solves your problem.
Old Sep 25, 2004 | 11:51 AM
fullracegsr's Avatar
Default Re: My Solution to Charge pipe popping off. (johnmay19)
maybe you should get rid of the home depot/ loews pipe couplers...
Old Sep 25, 2004 | 11:59 AM
m R g S r's Avatar
Default Re: My Solution to Charge pipe popping off. (fullracegsr)
I have silicon couplers with T-bolt clamp's on every other connection except there, I just didn't find a 2.75" silicon coupler. . .
Old Sep 25, 2004 | 12:06 PM
h22 civic's Avatar
yea get rid of that fernco coupling and get a t-clamp with some baker presicion hose and youll be alright
Old Sep 25, 2004 | 12:07 PM
Killer_B's Avatar
this is a great idea for someone that doesn't have access to a welder but PLEASE use that Tread LOCKING Liquid. you wouldn't want the nut on the inside to come loose and go into your motor.
Old Sep 25, 2004 | 12:24 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
Default Re: My Solution to Charge pipe popping off. (Killer_B)
have a beed welded around the end of the piping.
Old Sep 25, 2004 | 12:27 PM
mrbsponge's Avatar
that is how 1500HP turbo mustangs do it, they have one on just about every pipe, if can get a flaring tool, it might have stoppped the problem......i use 3M psray glue on my charge pipes and they NEVER come off!
Old Sep 25, 2004 | 12:37 PM
mamaboy's Avatar
Default Re: My Solution to Charge pipe popping off. (UJLSMoFo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UJLSMoFo &raquo;</TD></TR><TR><TD CLASS="quote">have a beed welded around the end of the piping.</TD></TR></TABLE>
+ hair spray. ghetto but it gets the job done
Old Sep 25, 2004 | 12:53 PM
AlphaMike's Avatar
Default Re: My Solution to Charge pipe popping off. (mamaboy)
Good Idea My friend used a ratchet strap wrapped around the IC and the IC piping to keep his from coming off.
Old Sep 25, 2004 | 01:10 PM
twkdCD595's Avatar
some small weld'd dots around the perimeter of the ends of my piping also did a nice job.
I wish I had access to a bead roller!
EK FLY
Welding / Fabrication
31
Aug 23, 2005 06:50 PM
98_4drCivic
May 27, 2005 08:54 AM
-Trinitron-
Oct 3, 2003 12:25 PM
jthelman
Feb 15, 2003 11:32 PM
redteg1
Jan 23, 2002 08:51 PM
