Just installed injectors and we have a problem...
Old Sep 25, 2004 | 01:36 AM
g2_boosted's Avatar
Default Just installed injectors and we have a problem...
I Installed new "DSM 450" Injectors tonight and We Installed the resistor box but we have a couple problems...
To Start it all from the beginning I ordered 4 dsm 450's off of RSX8600 or something like that from Honda-tech. I received them and found that most of the spintle caps were all broken but i searched and found out that they are still usable. So tonight we wire in the resistor box and did a nice lil job of making sure they were in but When installing I noticed a couple odd things. When I was putting the O ring seals on the injectors I found them to be a perfect fit in which was weird because i always hear that you hafta dremmel them down in order for 450's to fit. So then I Set up my VAFC for -40 Across the board and do a start up and i find my car to be idling like a pig, it would barely do much. So then I set it to -10 across and it seems to run perfect. I just have an air/fuel gauge right now because my wideband is still in shipping. The air/fuel gauge is just 1 bar in the rich side and the car feels pretty decent. But the point is that is there something wrong with the injectors because I should be taking more fuel away from them then just -10...
Thanx for reading that and If u have any other questions I will try to get u the answers ASAP
here is a pic of the injectors if you want to see them...
http://public.fotki.com/RSX8600/parts/dsm.html
Old Sep 25, 2004 | 01:49 AM
honda9369's Avatar
Default Re: Just installed injectors and we have a problem... (g2_boosted)
hmmm. thats weird. mine didnt fit perfectly. sounds like there 310s
Old Sep 25, 2004 | 01:52 AM
g2_boosted's Avatar
Default Re: Just installed injectors and we have a problem... (honda9369)
thats what I was kinda thinkin... Do they look like 310's? I think i got scammed...
Old Sep 25, 2004 | 05:40 AM
Smooth-GSR's Avatar
I'm not sure if those are 450's. Do a search here and find some pics to compare. It should say on the side of the injector '450' if they truly are.
Old Sep 25, 2004 | 06:06 AM
SOHC_MShue's Avatar
those don't look anything like my dsm 450's...they may just be from a different year though. Mine are blue on the top and say 450 on the side.
Old Sep 25, 2004 | 06:38 AM
adseguy's Avatar
Those really look like stock! Hmmm...what gives away the DSM's are the bottom injector nozzle. It looks nothing like the one in the picture. Can you pull any numbers off the injectors anywhere? Maybe someone can help with that
BTW I had to grind my seals as well so that could be a giveaway too
Old Sep 25, 2004 | 06:47 AM
RedTT's Avatar
Default Re: Just installed injectors and we have a problem... (adseguy)
my dsm 450 inj fit with no grinding at all. It was a very tight fit, but it worked with no modifying at all to the seals. Are you sure you have your settings right on the afc? When you go into the sensor type settings, you can set the type of map sensor in so many different ways. One number off can make it run way righ or way lean. I don't know about the vafc but my afc2 has these settings
Old Sep 25, 2004 | 06:50 AM
hoggy's Avatar
I have second gen injectors (non blue tops) and they don't look like that at all. Looks like you got some stockers or something of the sort.
Old Sep 25, 2004 | 07:01 AM
b_ron007's Avatar
i have the black tops DSM 450's, and the caps on the bottom were green. also, this is my in my accord, but they fit without any mods with the exception that it was a really tight fit, had to use dish soap to get em in.
Old Sep 25, 2004 | 07:12 AM
b_ron007's Avatar
these are what mine looked like, these aren't mine, but these are what they looked like. i was almost positive that the bottoms were green, soo i did a lil search just to back up what i said.........heres the proof!
"search button is our friend"
Old Sep 25, 2004 | 07:14 AM
b_ron007's Avatar
Default Re: (b_ron007)
these are urs
Old Sep 25, 2004 | 09:14 AM
g2_boosted's Avatar
Yeah Im a lil worried that they arnt Real DSM's. I wouldnt mind RSX8600 to come into this and say his part... umm on the vafc I have it set 6 in 6 out, throttle up to the right. i heared something about 98/99 but i dont know where to change that...
Old Sep 25, 2004 | 09:39 AM
rioninja's Avatar
Those are not DSM 450s.
You've been scammed...
Old Sep 25, 2004 | 12:53 PM
RSX8600's Avatar
Default Re: (g2_boosted)
i have no idea at all i sold these for a friend i can ask him again waht car he told me to sell these 450 dsm injectors for him that he had on his 95 ex turbo civic. im sorry thats all the info i got.
Old Sep 25, 2004 | 01:43 PM
tvrsir's Avatar
Default Re: (RSX8600)
they are stock first gen honda injectors man. the reason your car wouldn't ideal at -40 because you are leaning the hell outta it.
rsx8600 tell your freind to give back the man's money.
Old Sep 25, 2004 | 01:44 PM
RSX8600's Avatar
i don't have time to play around and i dont' sell fucked up/wrong parts this was for a friend and i told him im going to give u the money back cause i still had it and he said that was fine se let me knwo what u want.
Edit; i know him good and tell u the truth he might have mixed them up with the dsm those if are sotck i dont know might be the ones for his civic ex but no matter what im sure we can work this out cause i dont want this coming out on me.
Old Sep 25, 2004 | 02:03 PM
rioninja's Avatar
good man
Old Sep 25, 2004 | 04:02 PM
g2_boosted's Avatar
Default Re: Just installed injectors and we have a problem... (rioninja)
Well He seems really nice about it and im sure we can work it out! Anybody know where i can get dsm 450's that are in good shape?
Old Sep 25, 2004 | 04:14 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_boosted &raquo;</TD></TR><TR><TD CLASS="quote">Well He seems really nice about it and im sure we can work it out! Anybody know where i can get dsm 450's that are in good shape?</TD></TR></TABLE>
I almost bought those of of him! I'm glad I didn't. There have been many "FS" threads in the FI classifieds lately w/ both gens of DSM injetcors. Should be very easy to pick up a set $50-$75.
Phil
Old Sep 25, 2004 | 05:32 PM
RSX8600's Avatar
Default Re: Just installed injectors and we have a problem... (hondaguyef)
i paypal you the money back and please send thos injectors back out to me asap so i can give them to him. Thanks sorry for this im not a bad seller never was never will be lata 8600
Old Sep 25, 2004 | 05:52 PM
honda9369's Avatar
Default Re: (tvrsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrsir &raquo;</TD></TR><TR><TD CLASS="quote">they are stock first gen honda injectors man. the reason your car wouldn't ideal at -40 because you are leaning the hell outta it.
rsx8600 tell your freind to give back the man's money. </TD></TR></TABLE>
lean is mean. how long did u drive on those injectors
knoxer323eg
Sep 10, 2010 02:27 PM
ppfalcon
Jan 16, 2006 01:38 PM
b16hatche
Oct 24, 2005 08:03 PM
spacetuna
Aug 14, 2003 10:09 AM
sivik2nr
Jun 11, 2003 09:59 PM
