sleeves qestion...
Old Sep 25, 2004 | 09:18 AM
b_series_boy's Avatar
Default sleeves qestion...
Hey I was wondering if anyone knew how much psi stock sleeves can handle in a b18 block.
Old Sep 25, 2004 | 09:31 AM
Boosted2K's Avatar
Default Re: sleeves qestion... (b_series_boy)
NOT PSI
roughly 300WHP tuned right
Old Sep 25, 2004 | 09:35 AM
95GSRTT
Guest
Posts: n/a
Default Re: sleeves qestion... (Boosted2K)
tuned right it can hold up to 400+ whp. Its also based on how the block is right now and whether it was treated like **** before hand.
Old Sep 25, 2004 | 09:45 AM
Boosted2K's Avatar
Default Re: sleeves qestion... (95GSRTT)
Sorry, I thought he said stock block, I've seen stock sleeves go up to 400-450
Old Sep 25, 2004 | 10:36 AM
fullracegsr's Avatar
475whp w/block guard... would have went over 500 but my boost controller is too the max...
Old Sep 25, 2004 | 10:58 AM
nebulight's Avatar
Default Re: sleeves qestion... (fullracegsr)
I'm new to hondas, and I didn't feel like making a new thread for fear of being flamed, but can someone point me into the right direction for info, or post info on sleeves. We don't do that stuff with VW motors, but I think I'm going to start building a honda since I have a garage now and can let the car sit for months at a time if need be. I did try to search, but came up short. Thanks.
Old Sep 25, 2004 | 05:53 PM
m R g S r's Avatar
I know that Geoff made over 500 on stock sleeves, before spinning a bearing. 511whp I believe.
Old Sep 25, 2004 | 09:52 PM
I'm building my block with arias pistons and egale rods...and im boosting it with a turbonetics t4. I dont really have the money to sleeve my block because im impationate and i cant wait to boosted i plan on doin it later but my question was how much boost would my block handle of coarse ill get it balanced and blueprinted and with just pistons and rods cause i dont really have easy access to a dyno to measure hp.
Old Sep 26, 2004 | 05:42 AM
The Racing Line uk's Avatar
I used to split blocks open at 10psi on my B16. it used to run 7 - 8 psi no probs producing 225 whp. with standard cams and 8:1 je pistons
If you block guard it it will run 15 psi. i found any more than that the cylinders bowed slightly below the block guard, so i sleaved it too
You can see my pictures at my old website http://www.mod4me.com then selevt engine mods on the left hand side.
If the ignition is mapped correctly ie giving .75 degree of retard per lb off boost (min) a standard block with no block guard will run up to 10 psi.
i ran standard ignition map when i used to split blocks.
I hope this helps
Old Sep 26, 2004 | 01:09 PM
Default Re: sleeves qestion... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I know that Geoff made over 500 on stock sleeves, before spinning a bearing. 511whp I believe.</TD></TR></TABLE>
and that block last a rediculous amount of time... he travel all over the east and west coast with that civic... and drove it almost every day!!
Old Sep 26, 2004 | 09:56 PM
im just tryin to decide if i should go ahead and sleeve my block because i already have the motor pulled and i know im gonna get boost happy and i dont wanna ruin the bottom end
Old Sep 27, 2004 | 06:34 AM
nebulight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_series_boy &raquo;</TD></TR><TR><TD CLASS="quote">im just tryin to decide if i should go ahead and sleeve my block because i already have the motor pulled and i know im gonna get boost happy and i dont wanna ruin the bottom end</TD></TR></TABLE>
well, if the motor is out, and you have the cash, I'd say do it. Don' spend a lot of money then just blow it up.
Old Sep 27, 2004 | 06:36 AM
AspectIndustries's Avatar
Default Re: sleeves qestion... (nebulight)
Ive seen sleeves go past 500whp. So, the stock sleeves have enough potential.
Old Sep 27, 2004 | 11:28 AM
quickcarl's Avatar
Check out http://www.erlperformance.com for info. . While there you can check out Honda's Factory drag car in the gallery.
Old Sep 27, 2004 | 12:49 PM
RyanEJ8's Avatar
Default Re: sleeves qestion... (The Racing Line uk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Racing Line uk &raquo;</TD></TR><TR><TD CLASS="quote">I used to split blocks open at 10psi on my B16. it used to run 7 - 8 psi no probs producing 225 whp. with standard cams and 8:1 je pistons
I hope this helps
So if I had a blockguard I would be just as safe with 15 PSI on a T25 as I would with 15 PSI on a T4/GT40 "Blowzilla".
If you want to make comparisons you must look at WHP measurements.
Old Sep 27, 2004 | 01:59 PM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_series_boy &raquo;</TD></TR><TR><TD CLASS="quote">Hey I was wondering if anyone knew how much psi stock sleeves can handle in a b18 block.</TD></TR></TABLE>
my buddy has done well over 400whp on stock sleeves. All he has is aftermarket rods and pistons and blockguard. He hammers it every chance he gets
Old Sep 27, 2004 | 03:01 PM
greenhotrod's Avatar
we made 520hp with a block gaurd with no problems with the sleeves.
Leric
Jul 23, 2013 08:12 AM
beyondstock
May 8, 2009 07:04 PM
laziebun
Oct 22, 2007 03:23 PM
_Endless_
Mar 11, 2004 06:37 AM
1.8T_EG
Jan 13, 2003 10:00 PM
