i want the t51r turbos sound
i watched a video on superhonda of a t51r turbo in a supra vs a juiced mustang. the turbo in the supra sounds so good. how can i get that sound without the 3,000 pricetag of that turbo?
Re: i want the t51r turbos sound (96integraLS)
this is BAD ***!
You should also get the "ALWAYS ON VTHEC" Then you'll start creaming WS-6's
P.S> The whole thing is sarcastic even the Vt"h"ec. If you really want the sound you have to get the turbo . Look at the seller's comments. Some people said it sounds like *** or doesn't work.
If you are scared of real turbo because of the $3000 you shouldn't be. It can cost as low as $1500 if you want. I've seen one guy spend $790 (i think...i know it was in the $700 range) Just make sure you have good fuel managment (not FMU basically). Read around you can do it cheap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integraLS »</TD></TR><TR><TD CLASS="quote">i watched a video on superhonda of a t51r turbo in a supra vs a juiced mustang. the turbo in the supra sounds so good. how can i get that sound without the 3,000 pricetag of that turbo?</TD></TR></TABLE>
Re: i want the t51r turbos sound (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">
Re: i want the t51r turbos sound (EM1 MIKE)
most large turbochargers, esp. a ball bearing and twin inlet anti-surge housed unit.... will be very loud.
edit: how can people shell out 3-4k for a turbo alone... thats hella.
Modified by twkdCD595 at 2:54 PM 9/27/2004
Re: i want the t51r turbos sound (twkdCD595)
My FP3065 on my eclipse is just as loud as a T51R, guess why? Anti-surge compressor housing. Run a turbo with an anti-surge comp housing and it makes it a TON louder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">how can people shell out 3-4k for a turbo... thats hella.
You gotta pay to play.
Re: i want the t51r turbos sound (Finest)
Threadjack, but anyone care to give a bit more detail on what makes a turbo housing anti-surge?
I.E. what is different about it, and when specifically is it designed to prevent surge? Are we talking surge from crossing the surge limit on its compressor map, or surge from letting off the gas w/o a BOV?
Thanks-
Matt
Thanks-
Matt
ilovemyturbowhistler
09-08-2006 12:35 AM
