Turbo Problem. What could it be?
Old Sep 22, 2004 | 04:30 AM
J.P. 4rm The dPk*'s Avatar
Default Turbo Problem. What could it be?
The first 10-15 min regular driving the car is fine. After 15 min or so the car drops at about 300 RPM at idle soon after a few seconds it will jump back to around 900 RPM. Also Driving normally the car will totally bog down. Practically to the point where the car wont move until i reach boost and it just seems fine. Same as if i were on the streets or freeway. Bogging problem at low RPM's before boost.
My setup:
OBD-1 Bone stock 1995 LS
stock ECU
stock injectors
stock fuel pump
vortech FMU 12:1
garrett t3/t4
rev hard manifold/FMIC
greddy type s BOV
delta gate waste gate 7psi spring
NGK BKR7E spark plugs
NGK wires
timing retarded to about 12-14
also running off the down pipe at the moment (would this be a problem?)
No CEL's at all
Just got the car out not too long ago. Was wondering what the problem was. Ive been searching the boards and reading about how it might be running to rich. Which makes me hesitant to put in a fuel pump and injectors which will only throw more fuel in. Please any input would be apprciated TIA.
Old Sep 22, 2004 | 05:26 AM
Default Re: Turbo Problem. What could it be? (Ooga Booga)
up
Old Sep 22, 2004 | 08:35 AM
TTT
Old Sep 22, 2004 | 08:38 AM
crispydee's Avatar
i had a problem like that anfter i had the inlet off. i just reset the ecu and it was fine again. I didnt get any CEL's either
Old Sep 22, 2004 | 08:47 AM
Default Re: Turbo Problem. What could it be? (crispydee)
what do you mean by inlet?
Old Sep 22, 2004 | 12:27 PM
crispydee's Avatar
sorry, the inlet manifold. when i put it all back together it would idle fine till it warmed up then rev to 1200 and drop back down to 600 and back to 1200 and so on. Spoke to a friend who has a honda tuning business who said to just reset the ecu. did it and it was fine again
Old Sep 22, 2004 | 06:52 PM
oic
Old Sep 22, 2004 | 06:58 PM
honda9369's Avatar
stock injectors? might want to get bigger inj. and a real ems
Old Sep 22, 2004 | 07:56 PM
93turbo16's Avatar
your timing is crazy. You should only do it maybe 6 degrees from stock... check your timing.
Old Sep 22, 2004 | 10:38 PM
djwest24's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">your timing is crazy.</TD></TR></TABLE>
yea....it's retarded way too much. i'd say take off a degree per psi of boost. tht should be more than adequate.
Old Sep 23, 2004 | 02:53 AM
Default Re: (quicksilver17981)
ahh ok. Isnt stock timing 16?
Old Sep 23, 2004 | 06:42 AM
Default Re: (Ooga Booga)
bump
Old Sep 23, 2004 | 08:16 AM
raene's Avatar
What's your fuel pressure? Mine does that when it's running pig rich, but it also does that when the timing is hella retarded, or it's running damn lean.
Old Sep 23, 2004 | 06:12 PM
Default Re: (raene)
thats interesting... im going to look into that i honestly think is running real rich. I dont hear pinging ot detonation.
Old Sep 23, 2004 | 09:02 PM
raene's Avatar
Pull the plugs and check the straps If it's that rich they'll be quite dark.
Old Sep 24, 2004 | 03:45 AM
Default Re: (raene)
yea dude its weird the actual thread of the plug is black as hell but the white tip is still white.
Old Sep 24, 2004 | 08:14 AM
bump
Old Sep 24, 2004 | 08:56 AM
raene's Avatar
I would think that means you're running very lean and stumbling. Cold base because it's a cold plug, so sooty deposits at the base, and white tip because it's lean; the strap usually stays warm. Try upping the fuel pressure.
Old Sep 25, 2004 | 05:03 AM
Default Re: (raene)
weird. So confusing meng
Old Sep 26, 2004 | 12:07 AM
Bump
jordan_civic
May 21, 2008 01:14 PM
91backslash
11
Apr 13, 2006 04:57 PM
alfee
May 23, 2005 04:30 PM
Integspeed21
Oct 3, 2004 12:48 AM
TeamCracka
Apr 12, 2004 06:19 AM
