FMU
Old Nov 30, 2004 | 10:50 AM
Go Fast Civic's Avatar
Default FMU
Is there a way to check if an FMU is bad ?
Old Nov 30, 2004 | 10:53 AM
PrecisionH23a's Avatar
Default Re: FMU (sportinemotions)
All FMU's are bad
Old Nov 30, 2004 | 10:55 AM
Default Re: FMU (PrecisionH23a)
Yeah not the best, but its the only thing i have for now. Seriously, is there a way to test them?
Old Nov 30, 2004 | 11:41 AM
anyone ?
Old Nov 30, 2004 | 12:24 PM
TRE_'s Avatar
i dont think that FMU's really go bad... you could take the top off and make sure the disc and everything is in there maybe?
Old Nov 30, 2004 | 01:47 PM
Cramerox's Avatar
Default Re: FMU (THE_HX)
yes check the diaphram for any rips.
If your car bogs- then fmu could be getting stuck.
Old Nov 30, 2004 | 01:49 PM
Sonny's Avatar
Default Re: FMU (Cramerox)
You need an underhood fuel pressure gauge and a mighty-vac style pump.
With the engine idling, pull the vacuum line off of the FMU. Hook up your mighty vac. As you apply pressure to the FMU, the fuel pressure should rise. If you have a 12:1 disk, putting 1 psi of pressure into the FMU should raise the fuel pressure by 12 psi. 2 psi of pressure will raise it by 24 psi, etc.
Your call will stall after a certain point from all of the excess fuel.
Sonny
Old Nov 30, 2004 | 02:24 PM
Default Re: FMU (Sonny)
thanks for your input guys its not a problem of running rich is a problem of running lean https://honda-tech.com/zerothread?id=1068379 thats the only weak link that i can find, if its not that then i dont know. would you be able to suck on the vacume line and create 1-2 psi ?
Old Nov 30, 2004 | 04:34 PM
i ran 10lbs of pressure via a tire pump to the fmu while the car was running. the car seemed to bog down a little but not much though, if the fmu was working correctly then wouldn't the car stall ?
Old Nov 30, 2004 | 06:21 PM
Old Nov 30, 2004 | 06:27 PM
slowpokesi's Avatar
i took mine all apart because i thought it was broken, i really dont see how one could be defective unless the rubber peice was torn, or if the slug was somehow jammed.
how do you know your running lean? do you have a wideband or a crappy autometer a/f gauge.
Old Dec 1, 2004 | 01:08 PM
Default Re: FMU (slowpokesi)
i took mine apart too and it all looks great, just like new. you can tell your car is running lean by the way it bucks and runs like ****. yeah i have an A/F guage too, but i dont just go by that.
scartail
Oct 12, 2004 11:53 AM
evil_elmo
Oct 13, 2002 02:15 AM
mikelcrx
Jul 14, 2002 05:03 PM
uneekcrx
May 27, 2002 06:41 AM
turbogsr13z
Apr 17, 2002 09:39 PM
