supercharger and nos Question???
Old Dec 4, 2004 | 01:39 AM
hahaitzsteven's Avatar
Default supercharger and nos Question???
i have a 2.0L b18b with 12 to 1 compression Fully built sleeved and Built head.... i was thinkin what is the best setup i should go ... Direct Port NOS or Votech supercharger which would make more power... any answers help
Old Dec 4, 2004 | 02:44 AM
eL`mIEkLo's Avatar
Default Re: supercharger and nos Question??? (hahaitzsteven)
its really a personally preference, constant power (charger) or the bottle when u need it. If uve never sprayed or arnt very use having a bottle around in the car. get a charger, as far as vortech..... not so sure
Old Dec 4, 2004 | 03:02 AM
N2O's Avatar
N2O
Default Re: supercharger and nos Question??? (eL`mIEkLo)
SPRAY IT!!!
Spray is more adjustable than a supercharger. If you set it up right and be smart with it. it will work fine.
Old Dec 4, 2004 | 04:08 AM
gitwidit's Avatar
Default Re: supercharger and nos Question??? (N2O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote">SPRAY IT!!!</TD></TR></TABLE>
Old Dec 4, 2004 | 04:19 AM
scoop's Avatar
There is no Hope without Dope!
Spray is more adjustable than a supercharger. If you set it up right and be smart with it. it will work fine.</TD></TR></TABLE>
Old Dec 4, 2004 | 05:26 AM
boostedcivicsir's Avatar
Mr. Badwrench
having 12:1's i would spray it. i think the compression is too high for boost.
Old Dec 4, 2004 | 08:41 AM
MooreBoost's Avatar
Default Re: supercharger and nos Question??? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">having 12:1's i would spray it. i think the compression is too high for boost.</TD></TR></TABLE>
Thats what I was thinking.
Old Dec 4, 2004 | 12:41 PM
00Red_SiR's Avatar
All Motor Mentor
Yep, and it's even a little high for nitrous as well so you'll have to run a very small shot initially and then spend some time on a dyno making sure the air fuel looks good. With that compression ratio it would appear that you built that engine to be NA. Have you decided to look at an alternate route? if so and you really like superchargers, you should drop your compresion down in the 10:1 range at least and I'd go with the ATI Procharger. Far better and safer than the Vortech and makes more power on pump gas.
Old Dec 4, 2004 | 01:40 PM
Thanks ... i have sprayed when i had stock internals with a 75 shot dry kit... So if i do spray direct port... ya know how much i should spray and how much estimate power i would make? i was think about ignition like MSD it all out but i wouldn't make as much power as sprayin or supercharger... I raced my freinds 13.6 350z and only hang with it at top end not really happy and thought it would make more power...
Old Dec 4, 2004 | 01:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (hahaitzsteven)
You can run 12:1 CR.... It will prolly need some high octane fuel tho.... I wouldnt suggest running a SC with that CR due to the fact that intake temps are going to be through the roof and with that compression... Its all in the tunning is what it boils down too...
Blaze
Old Dec 4, 2004 | 01:52 PM
boosted92's Avatar
Default Re: supercharger and nos Question??? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, and it's even a little high for nitrous as well so you'll have to run a very small shot initially and then spend some time on a dyno making sure the air fuel looks good. With that compression ratio it would appear that you built that engine to be NA. Have you decided to look at an alternate route? if so and you really like superchargers, you should drop your compresion down in the 10:1 range at least and I'd go with the ATI Procharger. Far better and safer than the Vortech and makes more power on pump gas.</TD></TR></TABLE>
Or he could drop his compression down, run a turbo, and blow the procharger or the vorturd away.
Old Dec 4, 2004 | 02:02 PM
Yeah, SC ain't going to do it ... i think i am go back to all motor HAHA sorry force inductions!!! or maybe still shoot... any thoughts of how much nos i can spray with direct port anyone?
Old Dec 4, 2004 | 05:27 PM
beerbongskickass's Avatar
If your looking for power go turbo...
Old Dec 4, 2004 | 07:50 PM
Default Re: (beerbongskickass)
HAHA ... Feeling for the all motor side for now all i need to do... is swap pistons and im ready.. but i give all motor a chance first
Old Dec 4, 2004 | 07:57 PM
MooreBoost's Avatar
Yeah, swap pistons and let us know how close you are to the 200 mark.
Old Dec 5, 2004 | 02:04 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahaitzsteven &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, SC ain't going to do it ... i think i am go back to all motor HAHA sorry force inductions!!! or maybe still shoot... any thoughts of how much nos i can spray with direct port anyone?</TD></TR></TABLE>
Check to see what the smallest jet combinations are and go with them. That'll probably work out to 25hp shot per cylinder for about 100hp boost total in a direct port system. A single fogger nozzle system would be better at no more than a 75 hp setting though (wet kit style).
Old Dec 5, 2004 | 07:56 AM
MooreBoost's Avatar
Default Re: (00Red_SiR)
Why would a single fogger system be better?
He can use jets designed for a motorcycle in order to achieve less power.
Old Dec 5, 2004 | 12:52 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (tegunderpressure)
It would only be better from the perspective that you can set the system at lower power settings than you can with a standard direct port system, which are typically designed to deliver 100hp shots and up.
If he has a direct port system great, but if not he can save some money and go with a standard wet kit which is also a lot easier to install.
Old Dec 6, 2004 | 08:43 PM
jdmek910's Avatar
ATI????? PROCHARGER????
check my sig
selling complete kit for b series
best kit for taking ricers money because its hidden! LOL
nastyboyz98civic
Oct 15, 2008 09:28 PM
jugodmyko
28
Oct 27, 2007 06:56 PM
mike93eh2
Nov 29, 2006 08:41 AM
wade
Mar 25, 2005 03:01 AM
azhatch
13
Jul 30, 2004 10:57 PM
