EBC or MBC?
Old Dec 1, 2004 | 10:52 AM
fafsa's Avatar
Default EBC or MBC?
Very close to finishing my set up, wondering if it's worth it to cheap out and get a mbc or save up and wait for a ebc?
questions:
-Are mbc's annoying/hard to adjust?
-do they hold high boost (17-18psi) well? anyone running high boost have a mbc?
-Which brands mbc's are good? turbo xs/turbosmart/ect..
Old Dec 1, 2004 | 11:16 AM
boostsohfast's Avatar
Default Re: EBC or MBC? (fafsa)
What kind of setup do you have? I used to run a greddy profec and had problems with it so I switched to a Joe-P manual boost controller.
Old Dec 1, 2004 | 11:34 AM
fjt's Avatar
fjt
I have a Turbonetics MBC, it is easy to adjust and so far it holds boost pretty well..
1st and 2nd gear reads steady 10PSI..3rd gear reads 9.5PSI and 4th gear 9 PSI so overall so far it just looses 1 PSI at higher gears.. Thats when we tested it..
I now have it set at 9PSI
Old Dec 1, 2004 | 11:41 AM
fafsa's Avatar
Default Re: EBC or MBC? (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">I have a Turbonetics MBC, it is easy to adjust and so far it holds boost pretty well..
I now have it set at 9PSI</TD></TR></TABLE>
Yeah, thats what i was afraid of. but 1psi isnt that bad. Anyone have a mbc running high boost? im wondering if the drop off with high boost is the same or worse than low boost?
fjt, where did you get yours from and how much did you pay?
Old Dec 1, 2004 | 11:42 AM
I have mine set on 10 psi and it holds it steady throughout all gears. You can get them from boostcontroller.com... I like it better than the profec because it doesn't give me any problems... As for setting it goes, its not that hard... Just gradually work your way up on the boost controller until you reach what you want and you're done.
Old Dec 1, 2004 | 01:01 PM
donkiman's Avatar
with some of the electronic ones you can set different psi for different gears to gain better traction. as well as having a low boost and high boost setting which is nice. but the Manuals work just fine. im using a turboxs and it works great. i also have a hallman manual for sale if your interested. and no they are not anoying or hard to adjust.
Old Dec 1, 2004 | 01:07 PM
KevronsEG's Avatar
Default Re: EBC or MBC? (donkiman)
anybody runnign the turboXS dual stage? if so how is it?
thanks guys
Old Dec 1, 2004 | 01:10 PM
Bailhatch's Avatar
How do you know it's the BC? I have seen plenty of setups that have fluctuating boost with nothing more than a wastgate to control boost.
They should really call boost contollers, wastegate controllers.
Old Dec 1, 2004 | 01:31 PM
B18Flip's Avatar
The only thing i didn't like about my MBC (ebay ball/spring type) was that boost would increase a bit as the weather got cooler, thus needing minor tweaking w/ temp changes. It cost me an easy win one time because i kept hitting my boostcut
Old Dec 1, 2004 | 02:03 PM
john d
Guest
Posts: n/a
Default Re: EBC or MBC? (B18Flip)
this is fafsa at john's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">The only thing i didn't like about my MBC (ebay ball/spring type) was that boost would increase a bit as the weather got cooler, thus needing minor tweaking w/ temp changes. It cost me an easy win one time because i kept hitting my boostcut </TD></TR></TABLE>
how much boost were you running?
someone answer my question about how boost holds with mbc's at high boost
Old Dec 1, 2004 | 03:01 PM
PrettyLude's Avatar
its really a tradeoff, one way or another, the mbc has the cheap price, the electronic one has the high price, but you get consistent results, i would rather spend the money on the electronic one, rather than having the manual spike and destroy your motor
Old Dec 1, 2004 | 03:09 PM
Bailhatch's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">its really a tradeoff, one way or another, the mbc has the cheap price, the electronic one has the high price, but you get consistent results, i would rather spend the money on the electronic one, rather than having the manual spike and destroy your motor</TD></TR></TABLE>
It seems to be the exact opposite in practice. MBC tend to be very reliable and consistant vs. EBCs that tend to reset, not hold boost, not hold it consistantly etc.. look at J Davis' Profec thread https://honda-tech.com/zerothread?id=1058473
Old Dec 1, 2004 | 03:11 PM
Dsm634's Avatar
LOUD NOISES
Default Re: EBC or MBC? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">this is fafsa at john's.
someone answer my question about how boost holds with mbc's at high boost </TD></TR></TABLE>
I have the turbo xs manual and have been running 18lbs for a year with no problem.
When is does get cooler out though, it tends to up the boost by a pound or so, which is easily corrected with a half or full twist. *shrug*
Old Dec 1, 2004 | 03:46 PM
john d
Guest
Posts: n/a
Default Re: EBC or MBC? (Dsm634)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dsm634 &raquo;</TD></TR><TR><TD CLASS="quote">
When is does get cooler out though, it tends to up the boost by a pound or so, which is easily corrected with a half or full twist. *shrug*</TD></TR></TABLE>
thanks, anyone else running high boost with a mbc?
Old Dec 1, 2004 | 04:37 PM
john d
Guest
Posts: n/a
up
Old Dec 1, 2004 | 07:51 PM
coupon's Avatar
also want to know about mbc's on high boost
Old Dec 2, 2004 | 04:10 AM
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa &raquo;</TD></TR><TR><TD CLASS="quote">
fjt, where did you get yours from and how much did you pay?</TD></TR></TABLE>
Well my mechanic had it laying around the shop and he just installed it on my ride and let me use it
Old Dec 2, 2004 | 07:33 AM
B18Flip's Avatar
Default Re: EBC or MBC? (slowredhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowredhybrid &raquo;</TD></TR><TR><TD CLASS="quote">also want to know about mbc's on high boost </TD></TR></TABLE>
i forgot to say that evo 8 guys on evolutionm.net run MBC's anywhere from 19psi to 20+. Infact, i think about 50%-60% of them run Hallman's.....check out some threads and read members sigs (most of them will have Hallman EBC on there LOL)
Old Dec 2, 2004 | 08:22 AM
coupon's Avatar
i forgot to say that evo 8 guys on evolutionm.net run MBC's anywhere from 19psi to 20+. Infact, i think about 50%-60% of them run Hallman's.....check out some threads and read members sigs (most of them will have Hallman EBC on there LOL)</TD></TR></TABLE>
which does everyone recomend hallman or turbo xs?
Old Dec 2, 2004 | 08:45 AM
Sonny's Avatar
I have a Hallman Evo Rx in my RX-7. It's a great MBC. I've run as high as 14 psi with it and it's always been super conisistent and reliable. It was a little pricey since it comes with 2 springs and really light ceramic ball. It's a very nice looking piece though!
Sonny
Old Dec 2, 2004 | 12:14 PM
fafsa's Avatar
Default Re: EBC or MBC? (Sonny)
thanks, sonny. im trying to also narrow the choices down, so far its either hallman or turbo xs
Old Dec 3, 2004 | 07:45 AM
pbandj's Avatar
thanks, sonny. im trying to also narrow the choices down, so far its either hallman or turbo xs </TD></TR></TABLE>
also want to know what everyone thinks about the 2
hallman vs turboxs
Old Dec 3, 2004 | 08:00 AM
ScottEK's Avatar
Default Re: EBC or MBC? (pbandj)
I personally wasn't happy with my greddy profec B, I'm happy that I didn't have to pay the high retail price on it.
Old Dec 3, 2004 | 08:44 AM
coupon's Avatar
the turboxs is 10-20 more than the hallman, is it worth it?
Old Dec 3, 2004 | 02:39 PM
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowredhybrid &raquo;</TD></TR><TR><TD CLASS="quote">the turboxs is 10-20 more than the hallman, is it worth it?</TD></TR></TABLE>
would also like to know this
