stupid uberdata question (might apply to hondata)
Re: stupid uberdata question (Btothe3rdDegree)
Degrees of crank angle before Top Dead Center.
In order for what you see on the ignition base map to be accurate, you have to synchronize the distributor base timing at idle with the base map's ignition timing in the cells that it uses for idling.
Re: stupid uberdata question (Charlie Moua)
the car is done and running still needs alittle tweaking in the fuel section then i want to take it over to elite and get her tuned sometime this winter, thanks again for the seats charlie
Stock i believe is 14 deg btdc. So if you were to enter a neg number, yes it would be advanced, but way too much, the car would die. I am not even sure uberdata will accept a neg number, would probably just throw a cel.
JDMlyfestyle
23
05-19-2008 05:52 PM
brandond
01-16-2005 07:21 PM
