tunin the prelude
Old Dec 3, 2004 | 04:58 PM
LudeRacin99's Avatar
Default tunin the prelude
I just recently turbo charged my prelude and I know I need to tune it. Can I get it tuned w/ just the SAFC at the dyno, or do I need to get hondata or something like that. Thanks.
Old Dec 3, 2004 | 05:05 PM
94svtec's Avatar
Default Re: tunin the prelude (LudeRacin99)
I have the vafc II with 550's on an H23AVTEC with 10 lbs of boost. Knowing what I know now if I were you save your money for an engine management system not a band aid. Spending money on a standalone engine management system will be cheaper than rebuilding your internals. I know this first hand. I will be getting the AEM system pretty soon. Good Luck
Old Dec 3, 2004 | 06:01 PM
I'm probably goin to run just 8lbs...and shouldn't just an safc and maybe an ignition retarder be enough?
Old Dec 3, 2004 | 06:35 PM
94svtec's Avatar
I have the msd 6btm, colder ngk plugs, 550's and the vafc. Use the safc tune it with a wideband and then later on get a standalone system and tune it with a wideband then look at your HP numbers. Reliability issues also come into play. To be able to control ignition, timing, and fuel all in one unit would be the best solution in the end. The safc will work but just be sure to have it tuned with a wideband.
Old Dec 3, 2004 | 06:45 PM
TonyTurbolude's Avatar
Default Re: tunin the prelude (94svtec)
Old Dec 4, 2004 | 05:14 PM
Default Re: tunin the prelude (TonyTurbolude)
Would a greddy emanage w/ an ignition harness work well? Or should I just go for the hondata w/ boost option. Thanks guys
Old Dec 4, 2004 | 07:30 PM
pubestripe's Avatar
hondata is the better choice... at least where i live, more guys know how to tune hondata thatn greddy and it is cheaper... also, much easier to tune...
Old Dec 4, 2004 | 08:09 PM
littlebluecrx's Avatar
Give us a call 703 435 5000 we can help you out with a afc tuneup or a standalone such as aem or hondata. we are not far from d.c. and have inground dynojet... Jason
VTecLude1994
Oct 15, 2005 01:28 PM
boostedlude01
Apr 3, 2005 06:31 PM
skimb37
Apr 16, 2003 07:00 PM
iTR.EX
Dec 25, 2002 03:28 AM
accorracer
Oct 3, 2002 03:57 AM
