wiseco piston ring question(tough one)
Old Dec 1, 2004 | 06:35 PM
Trailz-EX's Avatar
Default wiseco piston ring question(tough one)
i just bought a set of wiseco pistons 9.0:1 coated 1/2mm over bore. the rings that came with them are file-fit, does any one know what the ring end clearance should be for a turbo application
Old Dec 1, 2004 | 06:37 PM
nicholashang's Avatar
Default Re: wiseco piston ring question(tough one) (Trailz-EX)
.018 is ok for both mid and top rings......... you don't have to file-fit the oil rings...
don't go over 25psi on WISECO..
I'd say only 20psi maxed out...25psi is pushing it!!!
Sonny's Avatar
I used Endyn's recommended gaps:
http://www.theoldone.com/artic....html
I have his Rollerwave pistons (they are Wiseco forgings). I don't think Larry uses the standard wiseco rings though.
I know a lot of people running JE's and CP's run a much looser gap than that, but I've had no troubles with my setup.
Sonny
Old Dec 1, 2004 | 06:47 PM
Trailz-EX's Avatar
Default Re: wiseco piston ring question(tough one) (nicholashang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang &raquo;</TD></TR><TR><TD CLASS="quote">
only 10 psi, just trying to build a reliable daily driver, wanna keep it conservative so it stays alive longer
thanks for the help
Old Dec 1, 2004 | 07:05 PM
powerofdreams8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang &raquo;</TD></TR><TR><TD CLASS="quote">.018 is ok for both mid and top rings......... you don't have to file-fit the oil rings...
Are you saying wiseco's are only good to 20 psi?
Old Dec 1, 2004 | 07:11 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang &raquo;</TD></TR><TR><TD CLASS="quote">.don't go over 25psi on WISECO..
Ya, and don't even think about using them in a a car with tan interior
Old Dec 1, 2004 | 07:50 PM
RenoRacing's Avatar
Default Re: wiseco piston ring question(tough one) (Bailhatch)
^bwahahaha...
Modern91Hatch
Jul 13, 2006 02:57 PM
HondaGuy02
May 22, 2005 01:47 PM
Sport_Injected
Jul 29, 2004 03:15 AM
EKB18BPR3
Jul 10, 2004 04:17 PM
sweet
Apr 23, 2003 05:06 PM
